Door Latch? What's up with those? #758805
07/26/10 10:12 PM
07/26/10 10:12 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
Need to replace the door latch on my 67 coronet convertible. Are the latches the same from left to right? Would a latch from a 66 fit?
Thanks Moparts!
Re: Door Latch? What's up with those? [Re: Coronet-R/T-Rag] #758806
07/27/10 05:06 PM
07/27/10 05:06 PM
Mid Michigan
Mid Michigan
El Bumpo......
Re: Door Latch? What's up with those? [Re: Coronet-R/T-Rag] #758807
07/27/10 07:47 PM
07/27/10 07:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I believe they are different L to R.The 66 should be the same.You are asking about the ones that are inside the door correct? Rocky
Chrysler Firepower
Re: Door Latch? What's up with those? [Re: therocks] #758808
07/28/10 08:02 AM
07/28/10 08:02 AM
Mid Michigan
Mid Michigan
Yes, I'm looking to replace the one inside the door. I thought they were the same from side to side. thanks.
Re: Door Latch? What's up with those? [Re: Coronet-R/T-Rag] #758809
07/28/10 09:23 AM
07/28/10 09:23 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Look at how they attach to the door.If you use a laft on right the opening would be to the door skin instead of facing to the inside.The strikers are the same on the body.Rocky
Chrysler Firepower
