Re: Trans fluid capacty 94 Dodge Caravan
[Re: 05dakota]
#758674
07/26/10 09:49 PM
07/26/10 09:49 PM
Posts: 242 Upland, California
Spode
Upland, California
it should have a dip stick.
and needs AFT+
yes there is a dipstick ,,,,,,,,Ok Ill buy two gallons and check just didnt want to drive three miles a couple of times.
[Re: Spode]
#758675
07/26/10 10:06 PM
07/26/10 10:06 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
Mitchell says 9.1qts for overhaul, and 4qts for service. And dex III should be fine.
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: stumpy]
#758677
07/26/10 10:40 PM
07/26/10 10:40 PM
Posts: 10,647 S.E.Ohio
Magnumguy
S.E.Ohio
YOU MUST USE ATF + !!
you will be rebuilding it again if you don't.
[Re: Magnumguy]
#758678
07/28/10 03:16 AM
07/28/10 03:16 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
They guys that did the fluid and filter on my 99 where blowing the air gun inside the differential while waiting for the silicone on the pan to dry.
I asked what's up with that?
They explained it will drip all day long without this move. With the air shot up in there. It gives them a few seconds of no dripping to slip the pan back in place without getting fluid on the silicone.
If you don't get an answer by tomorrow. I can ask them how much fluid a Caravan takes. Is it a 604 trans?
