early 360 (71-73) main bearing question?
#758403
07/26/10 01:42 PM
07/26/10 01:42 PM
Posts: 162 monticello,ms
andy3965
monticello,ms
I have two of these blocks('72 and '73) and was wondering which main bearings everyone is using? the only ones i can find are 1/2 groove. i was hoping to use full groove.did a search and found where some folks said that you could use '74 and up bearings.has anyone done this? this is going to be for a 408 so i want to use the best available bearings.
thanks,
Andy
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: early 360 (71-73) main bearing question?
[Re: andy3965]
#758409
07/27/10 09:24 PM
07/27/10 09:24 PM
dartman366
Mt. Vernon, Ohio
nobody else has wanted to run fullgroove bearings in the early 360 blocks?no one has ever used '74 and up bearings in older blocks?like i said i searched around on the internet and found some info that said you could use the later bearings,but some said you couldn't.i did find some 3/4 groove but was really hoping to use full groove.anybody???????????
Can't remember the part# but I just used two set's of mains to get the full grove set-up that I wanted, I have a 72 block and from what have heard the machining in the earlier block,s were supposed to be a smaller relief cut for the outer flange diameter of the thrust bearing and the later block's were machined bigger for a bigger bearing outer flange diameter, but some of the earlier block,s were machined for the bigger diameter,,,if I was told correctly.
[Re: dartman366]
#758410
07/27/10 10:04 PM
07/27/10 10:04 PM
andy3965
monticello,ms
yeah i thought about buying two sets but that would be over $100 easy. also thought about going ahead and getting the '74 and up full grooves, but if they didn't work then i would have to get two sets of the early bearings and be out that much more money!!! i was hoping that one of the smallblock experts would chime in and tell what they do on the early blocks.i may have to call ryanj and ask him. i sent him an email but haven't gotten a response yet.i'm sure he is real busy,so i thought i would ask here. i just need a deffinate answer (yes or no) about using the '74 and up bearings.
[Re: Baxter61]
#758412
07/27/10 10:55 PM
07/27/10 10:55 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am not have any problems running 1/2 groove bearings I spin it 7200 just looked at all the bearings after 100 passes and they all still looked like new.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#758413
07/27/10 10:57 PM
07/27/10 10:57 PM
dusturbd340W5
Kissimmee Fl.
oh my machinist also showed me an artical from Clevite showing that a full groove bearing could not carry the same load as a half groove
[Re: Performance Only]
#758415
07/29/10 12:48 AM
07/29/10 12:48 AM
andy3965
monticello,ms
thanks guys, i think i will just go with the 3/4 groove '71-'73.my truck should rarely see anything past 6800 so i think those will do
[Re: formula S]
#758417
07/29/10 07:57 AM
07/29/10 07:57 AM
andy3965
monticello,ms
formulas, thanks. thats the kind of info i was looking for. i will go ahead and pull the trigger on a set of full groove '74 and up bearings and try 'em out.
[Re: andy3965]
#758418
07/29/10 11:28 AM
07/29/10 11:28 AM
Posts: 660 San Diego
formula S
San Diego
Your welcome, Glad I could help
