Power Steering Flush #758324
07/26/10 12:37 PM
07/26/10 12:37 PM
Ca
speedy515 Offline OP
Ca
Does anyone know how to flush a power steering system?
I’ve removed the return hose, and had someone turn the wheel lock to lock while I turned the pump pulley. I repeated this until no more fluid came out of the return hose. I reattached the hose, filled the reservoir with clear/yellow fluid and repeated the above procedure until no air bubbles emerged.
The fluid in my reservoir is now reddish-pink. I’m sure that this is a result of some residual fluid mixing with my new clear fluid.
Is there a better way to purge the system of old fluid?
Speedy
Re: Power Steering Flush [Re: speedy515] #758325
07/26/10 01:42 PM
07/26/10 01:42 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
I would have been adding fluid while the return hose was off and kept turning it lock to lock until it came out clear.
My
Own
Personal
Adrenaline
Rush
Re: Power Steering Flush [Re: Moparzrule] #758326
07/26/10 02:19 PM
07/26/10 02:19 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
X2
Re: Power Steering Flush [Re: mopowergtx] #758327
07/26/10 04:15 PM
07/26/10 04:15 PM
Ca
Ca
I'll give it a whirl this afternoon
