Whistling from the carb, no power from motor. #758309
07/26/10 12:27 PM
07/26/10 12:27 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
A friend recently did a motor swap, and changed carbs at the same time.
The old engines carb was in bad shape, so he replaced it with a different unit on the new motor.
Now there is a whistling coming from the carb, he can find no obvious vacuum leaks. And while the motor does run, the truck is really low on power.
The motor was a good one, used for several years in another truck.
Any ideas what the cause of the whistle might be?
Re: Whistling from the carb, no power from motor. [Re: hp383] #758310
07/26/10 12:40 PM
07/26/10 12:40 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Did he change the timing chain.
Re: Whistling from the carb, no power from motor. [Re: hp383] #758311
07/26/10 04:33 PM
07/26/10 04:33 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
Did he use the correct carb for the intake? Spreadbore vs squarebore?
Re: Whistling from the carb, no power from motor. [Re: hp383] #758312
07/26/10 05:18 PM
07/26/10 05:18 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's a vacuum leak.
Many carbs have a large port in the back for feeding vacuum to a brake booster. Some of them use a pipe plug to seal it. That's a common area for leaks.
What kind of carb is it?
- Stu Harmon
Re: Whistling from the carb, no power from motor. [Re: hp383] #758313
07/26/10 06:18 PM
07/26/10 06:18 PM
Ca
speedy515 Offline
speedy515  Offline
Ca
Try this:
1)Run the engine at idle until warm.
2)Open up a propane torch, but DON'T light it.
3)Aim/hold the torch towards the area where you think the whistling may be coming from.
4) Since the leak is a vacuum leak, the engine's RPM will increase as the propane gets sucked in and
5) Viola
You've located your leak.
Re: Whistling from the carb, no power from motor. [Re: hp383] #758314
07/26/10 07:39 PM
07/26/10 07:39 PM
Alberta
rustbuckett68 Offline
Alberta
Use a couple feet of old heater (or garden) hose, One end close to your "good" ear, and wave the other end around suspected problem area. Very obvious. Can hear vacuum leaks, mechanical noise, various clicks and bangs, etc. Better than a stethoscope, and cheaper, too.
Re: Whistling from the carb, no power from motor. [Re: rustbuckett68] #758315
07/26/10 08:14 PM
07/26/10 08:14 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Stock or after market intake????
What type of carb????
Re: Whistling from the carb, no power from motor. [Re: SNK-EYZ] #758316
07/26/10 08:36 PM
07/26/10 08:36 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Probably not the case, but I had a fuel injected car that whistled and had no power when the catalytic converter element came loose and plugged the exhaust.
If he does have a Cat, bang on it and see if it rattles from the pieces bouncing around.
Re: Whistling from the carb, no power from motor. [Re: SNK-EYZ] #758317
07/26/10 08:51 PM
07/26/10 08:51 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
aftermarket alum intake, eddy i think, carb is a 600 eddy as well.
Re: Whistling from the carb, no power from motor. [Re: hp383] #758318
07/26/10 10:33 PM
07/26/10 10:33 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Sounds like a situation I once had. My whistling sound went away as idle was increased and the sound increased as idle was decreased. I searched all over for vacuum leaks, but found nothing. The problem ended up being the throttle bushing.
Re: Whistling from the carb, no power from motor. [Re: 1fastrunner] #758319
07/26/10 11:57 PM
07/26/10 11:57 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I once had a whistling vaccum leak on my LRE. I could not find the issue after checking everywhere, but it got louder and louder. This was confusing as I had recently put on a an M1 intake and new carb. Took it off and the black intake gaskets from ma mopar looked like potato chip crumbs. Replaced the gaskets and truck idled 900 higher. Tragic story, truck got totaled a couple days later.
Re: Whistling from the carb, no power from motor. [Re: moparmojo] #758320
07/27/10 12:56 AM
07/27/10 12:56 AM
A Red State
A Red State
On a buddy's car (440 with M1 intake) and a Holley carb it had a vacuum leak at the rear of the carb because he used one of the thin paper gaskets.
With that particular intake when using a Holley carb it exposed a vacuum passage to the outside at the rear center of the carb.
The manifold had a cast pedestal for one of the rear mounting bolts and a very thin flange around the throttle bores.
He had problems for months. He would pull the carb, install a new thin gasket and it would run okay for a short while.
Then it would start running bad, backfire and really start running bad and start whistling.
It was at the point that he needed someone else s opinion on it.
I helped him pull the carb started looking at it.
The gasket looked funny, like it had been blown down.
I turned over the carb, saw the large vacuum passage (pcv) and figured out that nothing was supporting it on the intake (since that area was open on the intake).
The fix was use either one of the 1/4 inch thick gaskets or 2 thin gaskets with a metal gasket/carb spacer in between them. He chose the latter option.
It cured the vacuum leak problem permanently.
Re: Whistling from the carb, no power from motor. [Re: SNK-EYZ] #758321
07/27/10 11:57 AM
07/27/10 11:57 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
yep, sounds like the same issue.
Re: Whistling from the carb, no power from motor. [Re: moparmojo] #758322
07/27/10 06:19 PM
07/27/10 06:19 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
As it was mentioned, if you are running an aluminum spreadbore eddy intake and a 600 eddy carb, you need this adapter kit, from edelbrock:
http://www.summitracing.com/parts/EDL-2732/
Re: Whistling from the carb, no power from motor. [Re: Pat_Whalen] #758323
07/27/10 09:25 PM
07/27/10 09:25 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Intake is a stock 340 cast intake, square bore. so its not the spread bore issue.
