six pack vaccume lines #757962
07/26/10 07:00 AM
07/26/10 07:00 AM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
at what port does the secondary vac lines hook up to? And at what rpm should the secondary's open up
Re: six pack vaccume lines [Re: mattpar] #757963
07/26/10 09:02 AM
07/26/10 09:02 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
center carb next to the choke pod, outboards next to secondary pod.different springs for different opening rates. lite for fast heavy for slow.
Re: six pack vaccume lines [Re: lokalik] #757964
07/26/10 11:45 AM
07/26/10 11:45 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Here's a pic.
Choke pull-off from center tap on front of base plate.
Lower fitting on metering block to vacuum pods.
Upper fitting to distributor vacuum advance (if used, otherwise cap this fitting)
Re: six pack vaccume lines [Re: ProStDodge] #757965
07/26/10 10:47 PM
07/26/10 10:47 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
thank you, do you know at what rpm would the secondaries normaly open up
Re: six pack vaccume lines [Re: mattpar] #757966
07/28/10 01:17 PM
07/28/10 01:17 PM
Brownsburg, IN. U.S.A.
speedjunkee Offline
speedjunkee  Offline
The RPM would depend on the springs you have in the secondairy and the load the engine is under.
Richard Dodrill
SpeedJunkee's Carbs and Performance
108 1/2 Grant St
Brownsburg, IN. 46112
317-292-3814
speedjunkeecarbs@comcast.net
Re: six pack vaccume lines [Re: mattpar] #757967
07/30/10 01:08 AM
07/30/10 01:08 AM
ProStDodge Offline
ProStDodge  Offline
The outboard carbs are opened by ported vacuum. Aas the motor starts to create vacuum under the center carb is wide open (basically when 350cfm is not enough). The secondaries ONLY open as needed - so you do not necessarily "feel" them open. The nice part of a vacuum system is it only gives the motor as much air as it can use which keeps it from bogging down from too much air.
Scott
Re: six pack vaccume lines [Re: ProStDodge] #757968
08/06/10 09:21 PM
08/06/10 09:21 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Someone else can give there input but I was always told that the line for the ouboards went on the main body port next to the choke and the dist. line went on the port on the metering block.What is right Dayclona?
Re: six pack vaccume lines [Re: 72 RR DUDE] #757969
08/06/10 10:22 PM
08/06/10 10:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Harold,...here's some factory lit pics to help ID the proper vac line fitting on the center carb for the secondary port,....click on word "attachment" to enlarge
Mike
Re: six pack vaccume lines [Re: DAYCLONA] #757970
08/06/10 10:22 PM
08/06/10 10:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
