Re: bodymen? evercoat metal to metal, or all metal?
[Re: upnover]
#757659
07/25/10 11:08 PM
07/25/10 11:08 PM
Posts: 11,881 Fallon, Nv
SeventyGTX
Fallon, Nv
USC makes good stuff but I have not used the product your speaking about. Metal 2 Metal is a crapshot. I have used it with good results years ago, but the last couple of cans we ordered were VERY thick and hard to mix the liquid hardener in correctly. If you are just looking for a good durable filler for the sectioned area, I use Evercoat Fibertech. It's similar to Kitty Hair or Marglas, but is super easy to use and hardens like concrete with regular creme hardener. Cleaning up the area to be filled is probably the most important step, no matter what you use. You can also etch prime the area before you fill for added durability. Don't take my word as gospel as everyone has their own preference to do things. But in 38 years, I haven't had anything fall out yet.
[Re: Mopargnome]
#757660
07/26/10 02:32 AM
07/26/10 02:32 AM
Posts: 2,675 Columbus Ga
reflections7
Columbus Ga
I have used all metal before with good results. Just make sure you add enough hardner. I didnt the last time I used it and had to scrape it off and start over.
It doesnt change color when you add hardner so its difficult to see when its completly mixed and it hardens real fast I have had the same problem but will use it on welded areas then finish with rage
[Re: elitecustombody]
#757664
07/26/10 01:16 PM
07/26/10 01:16 PM
Posts: 15,487 Florida
scratchnfotraction
my body man used it to shave the gas door,antinna,trim holes,small rust holes he said it has to be bare metal at the patch area(sand blasted it) works well,wont fall out,wont rust,ez to use/sand/work..then skim coat with filler
[Re: Ron Kirkpatrick]
#757671
07/26/10 01:58 PM
07/26/10 01:58 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I use short strand fiberglass on welded areas. I used the metal to metal and it seems to crack too easy.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
