340/416 sb ri\unning HOT suggestions PLEASE! #75762
06/18/08 10:11 PM
06/18/08 10:11 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
I've got a sb 416, new everything, re-cored, wider than stock, 3 core 26" radiator; running a factory shroud; new thermostatic fan clutch which I tested using the "3/4 tape test",- the fan seems to be turning fine. the fan blades are seting about 1 3/4 inch away from the radiator. there is a cleared, fins streightened, condensor and a new trans cooler in front of the radiator. new, if I remember correctly, 180# thermostat which I drilled two small holes to allow water flow. Theromostat is opening and closing. running a 50/50 mix with temp-cooler poured in. Engine is timed at about 35/36 degrees all in at about 3000 rpm.
The car has a factory temp gauge, which seems to be reasonably accurate. The problem is when I get the car crusing after about 5-6 miles the temp gauge is midway between hot and cold. Then creeps up a little more, just past midway...stays there then I get it home... idleing it begins to creep up toward hot...I shut it off. I can feel the water at a fast-boil when I feel the (hard) upper radiator hose. Header temps will vary between 400 and 1000+ (at #6, previously just after break-in #4 and #6 would be starting to glow! now they are down to 6-700)
Could there be a blocked water passage? The engine was nasty in a barn for a while when I got it. The machine shop, (who's attention to detail I seriously question) cleaned it and bored it as well as rebuilt the heads. The engine builder has no clue. I have had the car running about a year, during which time I have maybe put 40 miles on it due to hot header temps and now overheating worries. Any suggestions are welcome! Please help.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75763
06/18/08 10:20 PM
06/18/08 10:20 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
What is the temp that you are rising to? Coolant will always heat up and pressure rise after shut down do to heat soak the first few minutes with no circulation. So far I don't see a problem.
Thermostat can not control temperatures above the stat rating - just keep them from falling below the rating and to reach operating temperature slightly quicker.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75764
06/18/08 10:44 PM
06/18/08 10:44 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Glowing headers are indicative of late timing.
Before you start worrying yourself into an ulcer, you need to get a good mechanical temperature gauge so you will know exactly what the temperature is.
Did your engine builder remove the drain plugs in the block when he cleaned it? I'm betting no.
They can be a real bear to remove but you will be surprised what comes out of the block after 30+ years.
Once you find out the temperature with a good gauge, be sure to post it here.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: 340727dart] #75765
06/18/08 11:01 PM
06/18/08 11:01 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
New brass freeze plugs were installed after it was cleaned...I just question whether steel brushes were run through it to clean and ensure no blockage. When I worked at a maching shop 25+ years ago in high school I always ran brushes through the water passages in the block and heads because sometimes they would be clogged with dirt/flash/bars-seal.
I tried to run a mechanical temp gauge...I could not get one to fit in the stock location (motor looks factory, sans headers)
The motor, idleing runs hot! It i don't shut it down..The motor will be toast.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: 340727dart] #75766
06/18/08 11:03 PM
06/18/08 11:03 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You can lay a cooking thermometer on the cylinder head or the top of the radiator after driving it around to get a reasonable temp reading.
What do the spark plugs look like? Too lean might make it run hot too.
What type of waterpump do you have? Rubber seal on the radiator cap in good shape?
Spring in the lower radiator hose?
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75767
06/18/08 11:08 PM
06/18/08 11:08 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
I would also suspect late ignition timing.
Any ethanol in the fuel?
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparforLife] #75768
06/18/08 11:15 PM
06/18/08 11:15 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
When idleing it will move to HOT, I shut it down just befor it gets there. And this is ideling, after a 5-10 mile run, for maybe 5 minutes. properly rebuily motors, particularly sb's should not boil over....Move to and past HOT. I've had lot's of cars, rebuilt many motors (I should have built this one myself..but thought a professional would best serve me being it's a stroker...my mistake) anyway the motor is running hot.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: ToddP] #75769
06/18/08 11:24 PM
06/18/08 11:24 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
I run BP 93, however I wouldn't be suprised that ethanol is in the fuel. The carb is a demon-sizzler built thermoquad, according to him built for a stout motor; maybe on the slightly rich side. radiator cap is new with a good rubber seal. the ignition is a new MP electronic distributor with a chrome box.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75770
06/18/08 11:42 PM
06/18/08 11:42 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Modern summer blend fuels with ethanol burn very slowly.
A good test would be to set the idle timing to 25° btdc. Just let the engine idle and see if the idle operating temp drops.
Also mechanical advance all in by 3000 rpm is too slow.
A new style mallory / mp distributor is very adjustable . mechanical advance slots are eaisly adjustable with torx bit. as well as advance curves with lighter springs.
I would set advance curve as quick as possible
all in by 1600 to 1800 rpm.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75771
06/19/08 07:01 AM
06/19/08 07:01 AM
the temp is OK out on the road moving but there's only a problem at idle?(at home it creeps up to Hot). Unless your initial timing is not advanced enough then I would guess classic not enough airflow or inadequate water pump.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: RapidRobert] #75772
06/19/08 07:20 AM
06/19/08 07:20 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Is it a stock pulley set up, anything underdriven or did you mix and match componants? Maybe it's not spinning as fast as it should. I would set timing to 34 degrees max (recurved so it's all in around 2500). Are you running a hotter plug? If so maybe it's acting more like a leaner mixture. Compression ratio and overbore? Friction cause heat... break it in maybe it's still just too tight
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75773
06/19/08 08:33 AM
06/19/08 08:33 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Dan,
Do you have a leakdown tester? If so, you can see if the head gaskets are sealing correctly. Another way to check for this is to use a chemical indicator fluid that changes color if combustion gases are entering the cooling system. A company called Lisle Tools makes an inexpensive combustion leak detector kit (P/N 75500).
Even if either of these tests aren't positive, at least you've ruled them out as possibilites.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: mrob] #75774
06/19/08 09:00 AM
06/19/08 09:00 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Dan,
Nice to rule thes out but if the vehicle is getting hot only after shut then cylinder pressure should not be the cause.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: MoparDan] #75775
06/19/08 09:06 AM
06/19/08 09:06 AM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
I'm referring to the block drain plugs on both sides below the freeze plugs. They are located near the center of the block.
I've had blocks boiled and blown out with high pressure water with all the freeze plugs out until the water ran clear. But, when I removed the drain plugs, I couldn't believe the junk that came out.
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: 340727dart] #75776
06/19/08 10:43 AM
06/19/08 10:43 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
are you running vac. adv. i have a 360 that has run hot for 5 years. i did everthing that evrybody sugested. i recently put in a MP distr. and it started running cooler. yeah i am a happy man. above somebody said to adv it to 25 at idle and see if it helps. that would be almost the same thing.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: 340/416 sb ri\unning HOT suggestions PLEASE! [Re: 65cuda] #75777
06/19/08 12:49 PM
06/19/08 12:49 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Sounds like there's something generating heat, or the cooling jacket's crudded up. The block should be airless shotted, it blasts the crud off the cores, and boucnes all thru it, so everything gets cleaned. What oil pump are you running, and what pressure does it maintain? The latest 422 I did, even at 9.8:1 and +.060 overbore, runs cold with a similar setup. Only hits 180 on long light throttle hills in 90-895° heat. Good efficient engines dont run hot. And I think it's more than timing or fuel.
