Anyone see a problem with this??? #757107
07/24/10 11:49 PM
07/24/10 11:49 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I am installing a crank trigger and need to have a locked out distributor. I have a Mallory dual point dist that has an adjustable advance plate that can be set to zero advance.(no vacuum adv)
If I set this dist to zero advance and adj the points to not touch the cam, can this distrib be used with my crank trigger?
The only problem I've seen is that Mallory doesn't make a cap to fit this distrib that uses male plug wire terminals, only the old female style.
This will save me about $250 and if I have a problem with the crank trigger or 7AL2 box, I could adjust the points and run it "old school".
Thanks ,Brian Dunnigan
Re: Anyone see a problem with this??? [Re: '72CudaRacer] #757108
07/24/10 11:55 PM
07/24/10 11:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I don't see why not
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Anyone see a problem with this??? [Re: dusturbd340W5] #757109
07/25/10 08:12 AM
07/25/10 08:12 AM
USA
DAK512 Offline
DAK512  Offline
USA
Get ahold of sunroofgtx he can make you any wires you need
Re: Anyone see a problem with this??? [Re: '72CudaRacer] #757110
07/25/10 08:26 AM
07/25/10 08:26 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
You could always use a leanburn dist. and use regular wires. Could be had cheap. Mine made over 900hp with one.
