70 cuda vert resto. rotisserie??? #757077
07/24/10 11:17 PM
07/24/10 11:17 PM
p.a.
420duster Offline OP
p.a.
Hello,I'm looking for some tips,advice please.I have a 70 cuda vert I'm restoring and I really want to put it on a rotisserie and do it right.BUT I'm afraid.I plan on bracing it on the inside,but not sure what else I can or should do.Thanks
Re: 70 cuda vert resto. rotisserie??? [Re: 420duster] #757078
07/25/10 12:52 AM
07/25/10 12:52 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
No reason to be afraid of putting a solid car on a rotisserie.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 70 cuda vert resto. rotisserie??? [Re: 420duster] #757079
07/25/10 09:08 PM
07/25/10 09:08 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
WhirlyJig brand of rotisserie has an attachment available that keeps the body of conv. cars from flexing.
Re: 70 cuda vert resto. rotisserie??? [Re: 420duster] #757080
07/25/10 10:15 PM
07/25/10 10:15 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
Just don't cut out allot of sheetmetal while its on the rotiserie !!! brace both doors before mounting it, the cudas flex like crazy... This one was rock solid, just needed a passenger front floor so the brace was as simple as a peice of steel welded across the opening.... I could have also added a brace up to the windshield but didn't feel it was needed on this one... If you're doing 1/4's, trunk, wheelhouses etc... then it's better to do that work on the ground first with the car still on its wheels or axle stands, then when its solid again you can mount it on the rotisserie for finish welding and primer... preping the underside and engine bay etc is made easy with a rotisserie but all final panel alignment and finish bodywork should be done on the cars wheels or on a body cart.
