Piston top volume #755810
07/23/10 10:57 AM
07/23/10 10:57 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I am trying to figure out the compression ratio on my 360. I'm running KB190-.030 pistons how do I figure out the piton top volume on these.
Re: Piston top volume [Re: flatiron] #755811
07/23/10 01:12 PM
07/23/10 01:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://www.kb-silvolite.com/kb_car/performance.php?action=details&P_id=15
means you subtract 1.2 cc to total of gasket and head CC.
this is before any machining to give proper quench
say you mill nothing if you have 72 cc head and 8 cc for a composition gasket 72 + 8 - 1.2 = 78.8 compression chamber volume so 9.7 to 1.
Only real way to tell is down fill a cylinder and actually cc heads.
Re: Piston top volume [Re: flatiron] #755812
07/23/10 04:45 PM
07/23/10 04:45 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Curious what you came up with??? Can ya tell us more about your 360???
Re: Piston top volume [Re: MIKES_DUSTER] #755813
07/23/10 04:51 PM
07/23/10 04:51 PM
That only works with a .030 piston...What if you have .040 piston???
Re: Piston top volume [Re: MIKES_DUSTER] #755814
07/24/10 01:17 AM
07/24/10 01:17 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Mike,
Sorry you asked me about my engine build before and I dropped the ball and didn't get back. I will dig out my notes later today and post them. As It's suppose to get up into the ninety's and won't be doing much out in the garage.
