Re: Vac pump ET gains?
[Re: 412 SB Duster]
#755796
07/23/10 01:30 PM
07/23/10 01:30 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Has anyone added a vac pump to 400" SB Gas motor with low tension ring pack. If so What gains if any did they see in E.T Is it worth the money?
Thanks Al
It's worth the money to keep oil off the engine compartment! But I picked up .06 and it runs more consistant, oil free.
[Re: DavidDean]
#755798
07/23/10 02:59 PM
07/23/10 02:59 PM
Posts: 310 Michigan
412 SB Duster
Thanks for the replies, as to the smoking issue i don't have that problem Thankfully. Oil leaking is not a issue either. It maybe because I have 4 breathers on it to help from building pressure in the block. I like what I'm hearing about the pick up in ET. Any of you have pic's of your SB with the Vac pump installed. Thanks Al
