Freeze Plugs - how do you install them? #755705
07/23/10 07:04 AM
07/23/10 07:04 AM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
I have a 318 out of an 86 pickup that I'm trying to do a low buck replacement into another pickup with. A couple of freezeplugs from the block were rusty/leaking while in the 86. Never could get to them so just kept adding water.
Figure that while it's on the stand, I could knock them out and replace easily.
Do you just use a large socket that fits the plug and knock the new one in? Do you use any sealer while reinstalling?
Any opinions would be great, thanks!
mity225@mchsi.com
Always looking for my next project!
Re: Freeze Plugs - how do you install them? [Re: mity225] #755706
07/23/10 07:18 AM
07/23/10 07:18 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use a punch and turn the old on side ways and pop out and the like you said use a large socket and make sure to drive in straight. Make sure that the hole is clean and use some permatex or Indian Head on the edges of the cup. I also like using the the deep core plugs rather than the ones with thin shoulders.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Freeze Plugs - how do you install them? [Re: mity225] #755707
07/23/10 07:18 AM
07/23/10 07:18 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Find a socket & extension that is a close fit on the inside diameter of the freeze plug and tap it in. I highly recomend the deep plugs, they have a longer lead and are a lot easier to seat. Just did one with the engine in the car...Getting them out is messy, but just don't damage the cast iron that holds them in. Also, using some sealing goo is cheap insurence not to have any leaks.
Re: Freeze Plugs - how do you install them? [Re: Dragula] #755708
07/23/10 07:22 AM
07/23/10 07:22 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: Freeze Plugs - how do you install them? [Re: cogen80] #755709
07/23/10 08:57 AM
07/23/10 08:57 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Yep and change them all while you have the motor out--chances they are all getting thin by now.
Also, brass is nice and will last longer, but they cost a little more.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Freeze Plugs - how do you install them? [Re: Dragula] #755710
07/23/10 10:12 AM
07/23/10 10:12 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
I just drill a small hole in the center of them, turn in a screw that's a couple inches long and then use pry bar to pull them out. If the screw pulls thru and the plug doesn't come out, just step up to a bigger screw.
Re: Freeze Plugs - how do you install them? [Re: wingman] #755711
07/23/10 10:14 AM
07/23/10 10:14 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I always replace mine with brass and then use J-B Weld. I don't intend to ever have to worry about them again. On a race block I've been known to tap em with a pipe thread and screw in pipe plugs.
Re: Freeze Plugs - how do you install them? [Re: mity225] #755712
07/23/10 10:15 AM
07/23/10 10:15 AM
what they said, The thick "Dorman" brand steel ones at your parts house not the thin "Pioneer" ones & Permatex #1 in the toothpaste like tube (thick & viscous). Alot of people use brass w no probs but I feel steel grips tighter. some plugs are close to the cyl wall so be carefull on which ones you tap sideways on removal (if it stops dont force it).
Re: Freeze Plugs - how do you install them? [Re: mity225] #755713
07/23/10 10:41 AM
07/23/10 10:41 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
And don't forget there are a couple in the rear china wall(bellhousing face).
This space available for rent
Re: Freeze Plugs - how do you install them? [Re: mity225] #755714
07/23/10 02:48 PM
07/23/10 02:48 PM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
Great replies. I like skewering them with a screw and prying them out.
I'll have to use the sealer as extra insurance.
Thanks!
JK
Re: Freeze Plugs - how do you install them? [Re: mity225] #755715
07/23/10 04:04 PM
07/23/10 04:04 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I'd definately clean the hole first. Perhaps a properly sized wire wheel or flap wheel would work great but even some paper by hand would work.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
