Page 3 of 3 1 2 3
Re: LA 915 heads on top a 318 [Re: mopowergtx] #755660
07/24/10 10:43 PM
07/24/10 10:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Over the years I have put any number of heads on my 87 318, stock 302's, 915's, even 315's all with 4bbl intakes, stock Tquad style and Edelbrock Performer.
On the 318 there was NEVER enough difference to justify the cost of the gaskets. All stock, untouched heads.
The only combo that made a substantial difference, to me, was the 360 with 302 heads. But I wouldn't spend more than the cost of a gasket set on a 302 swap myself.
On a mild build the port mismatch between a 4bbl intake and a "318 head" is unnoticeable. If you think you notice it you are fooling yourself.
Don't be the exception.
Re: LA 915 heads on top a 318 [Re: Locomotion] #755661
07/24/10 11:09 PM
07/24/10 11:09 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Im going to fill my combustion chambers with JB weld to lower the cc on my 360 heads. Then they will work perfect on my 318.
I really hope you are kidding.
If you can repair a cracked cylinder wall with it then why cant you fill a combustion chamber with it?
Re: LA 915 heads on top a 318 [Re: derekeh] #755662
07/24/10 11:19 PM
07/24/10 11:19 PM
Eastern Ohio
mopowergtx Offline OP
Eastern Ohio
It would "blow" right apart the first time you fired it up. You'd never be able to repair a cylinder wall with it either. A water jacket maybe. Its best used where theres no pressure, or very low at least, being applied to it. I've fixed cracked crankcases on motorcycles with it but it was only holding back the oil and theres no pressure on it and its not required to have any structural strength where I put it.
Re: LA 915 heads on top a 318 [Re: RapidRobert] #755663
07/24/10 11:37 PM
07/24/10 11:37 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
I have a set of these, what bowl hog angle should I use?
I use the standard chrysler 75* and just clean up the bottom. Your top cut will also unshroud the valve. Don't get to fancy with the die grinder I've hit water on the crossover ex.
Randy
Re: LA 915 heads on top a 318 [Re: dodgefarmer] #755664
07/24/10 11:40 PM
07/24/10 11:40 PM
I use the standard chrysler 75* and just clean up the bottom. Don't get to fancy with the die grinder I've hit water on the crossover ex.
Thank you Randy, I'll be especially carefull. EDIT is that the short side (floor) radius that I need to be carefull with?
Re: LA 915 heads on top a 318 [Re: mopowergtx] #755665
07/25/10 12:17 AM
07/25/10 12:17 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I would pop those 920 casting heads on it and not think twice about the hardened seats (or lack there of). I have seen lots of mopar people running non-hardened seat heads without any problem. I ran a 6 dart for years with those 67 heads and when it finnaly spun a bearing the heads still looked great. They out flow the 302 head and they have slightly smaller chambers. You will not regret putting them on there. Also I would not worry about the port mismatch, been there done that and it was no issue at all.
Yeah Dave I rolled those 920's around today and they sure have a sweet looking combustion chamber. Shame they didnt retain it into a 2.02/1.60 head. No doubt with them I sure wouldn't lose any squeeze and you would think I'd pick up a better quench area. Heck might pick up some compression actually. I havent got a chance to look at a 70's 318 head yet to compare to. I should have some sitting around somewhere to get a peak at tomorrow.
Thank you. I was wondering about that. Something to think about since my 318 is 9.2.1 but, that's not the actual ratio.
Re: LA 915 heads on top a 318 [Re: mopowergtx] #755666
07/25/10 12:24 AM
07/25/10 12:24 AM
Escondido, CA
64physhy Offline
64physhy  Offline
Escondido, CA
Might want to go with a thinner head gasket than .040. I think stock ones are thinner than that (.038??). If you can find some good 302's for cheap that are ready to bolt on, put those on with .029 head gaskets, and your compression will go up a little.
Re: LA 915 heads on top a 318 [Re: 64physhy] #755667
07/25/10 10:42 AM
07/25/10 10:42 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the bolt locations for the AC on the mag head are the same as the LA's, it's just the lower one where the alternator attaches that is in a different plane.
stock mags don't have the heat crossover either
2017 Grand Cherokee Overland
Re: LA 915 heads on top a 318 [Re: mopowergtx] #755668
07/25/10 03:14 PM
07/25/10 03:14 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I agree. The top of the combustion chamber is a very hot and violent place. Nothing is hard enough there except pure metal (so far as I know, nobody is making plastic heads yet). And my bet is that when the JB comes off in chunks, those chunks will be hard enough to break holes in your aluminum pistons. Don't try it unless you really don't care about ruining the engine.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: LA 915 heads on top a 318 [Re: GO_Fish] #755669
07/25/10 09:15 PM
07/25/10 09:15 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Ive used a dremel and put W shape cuts at an angle in the combustion chambers. This will prevent the JB Weld from falling out. Ill post up some pics later! Hopefully in a week Ill have the heads ready to install. Ill be sure and keep everyone updated as to how it goes. Once I perfect this I plan on starting a business. I think it would really catch on as a cheap alternative to other ways of bumping compression.
Re: LA 915 heads on top a 318 [Re: derekeh] #755670
07/25/10 10:28 PM
07/25/10 10:28 PM
Eastern Ohio
Eastern Ohio
1967 318 LA 920 Castings.
I cc'ed them real quick tonight and got 63cc's on the one in the picture.
But now I see why the 318 heads cc a little smaller than 360 heads too. The combustion chambers are smaller diameter. So that would account for a late model open chamber 318 being less than a 360 of a similiar year by a small ammount. I was looking at a 675 casting 318 and noticed it. It looks like they used those 675's on 318's from 1968-1974 so that would answer a question further back about are 1968 heads open chamber. Yep. I didnt get a chance to cc one of them. I will just for general purpose sometime this week.
Re: LA 915 heads on top a 318 [Re: mopowergtx] #755671
07/25/10 10:58 PM
07/25/10 10:58 PM
Middle of A Field
O
O
Middle of A Field
Thank you for the response. I look forward to see what your findings are on the later heads. Take care.
Page 3 of 3 1 2 3
