Tire rollout -Will I notice?? #755604
07/23/10 12:34 AM
07/23/10 12:34 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Having trouble hooking my car with my ET street radials. The conditions have to be just right or I blow the tires off. I had it close at Thompson and made some spring and shock adjustments and went to Quaker and made eleven passes on three days the 60' were all from 1.50-1.54 and life was good. I go back to Thompson Wens. I was all over 1.80,1.73,1.80,1.69. I'm thinking about trying Hoosier Q.T.P people say they are a little more forgiving. My ET radials are 315/60 with a rollout of 94" and the Q.T.P. tire 29/13.5 is 92". Will I notice a change?
Re: Tire rollout -Will I notice?? [Re: fattire] #755605
07/23/10 12:43 AM
07/23/10 12:43 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Its not the tire....
Re: Tire rollout -Will I notice?? [Re: 9 Sec Phill] #755606
07/23/10 01:07 AM
07/23/10 01:07 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
What are your thoughts?
Re: Tire rollout -Will I notice?? [Re: fattire] #755607
07/23/10 01:38 AM
07/23/10 01:38 AM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
My thoughts... ...I think the MT street radial is the best street tire on the market. If you cant hook with this tire you have other problems. Your front suspension or chassis is not set correct. There are guys running 7 sec passes(1/4) on smaller tires. What is your PSI, I use to run around 18PSI. I have ran these tires since they came out and will not run another brand. I have gotten 1.36 60' time with my old street car running MT street radials. Is your car an auto or stick? How do you leave, at idel or on the converter or do you use a brake. Testing should be done to see what the tire/car likes. If its spinning why is it spinning? Are you getting the tire hot? How do you do a burn out?...Is the front end traveling like it should. If you can barrow a set of slicks and do a test at the track, run the radials and then the slicks..I bet you the radials will be faster and lower ET then the slicks. I know not all cars are the same. And not all cars will hook the same. But these tire have the best bite ive ever seen from slicks to DOT street racing tires. Get some video of the car, see what its doing on the line, how it reacts...Testing,testing,testing...You will get it to hook on the Radials, trust me....Phill
Re: Tire rollout -Will I notice?? [Re: 9 Sec Phill] #755608
07/23/10 02:48 AM
07/23/10 02:48 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Thanks for the advice but I have used 130#,150#,170# springs works best with the 150#. I have adjusted the shocks from 1 through 5 on my QA-1s. I have ran the psi from 18 all the way down to 12 psi. I have left from idle to all the way up on the convertor so you can see it's not like I went out one time and spun. The only place I fall short is the front end where the up grade is a set of QA-1 adjustables and thats it. I would like to make the car work with a set of $400 tires before I would spend major money on the front suspension. I have used these tires on other cars and they worked fine but like you said not all cars are the same.
Re: Tire rollout -Will I notice?? [Re: fattire] #755609
07/23/10 04:21 AM
07/23/10 04:21 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Just another point to consider. Whilst I can't comment on M/T Drag Radials, I have used M/T Radial slicks. I found these to be very dependant on the track prep. On a good track they hooked better than the regular bias ply but the bias ply are more forgiving on a less well prepared surface. HTH's
Re: Tire rollout -Will I notice?? [Re: Tig] #755610
07/23/10 07:39 AM
07/23/10 07:39 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I am running a pro drag radial on my Challenger. It is not a street tire but radials are way less forgiving than regular bias slicks. I can race my car at four out of the five local tracks we have around here. The other track I can never get down without just completely blowing the tires off of the car. They are dependent on a good surface. The track prep at the track your having problems with is most likely the cause.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Tire rollout -Will I notice?? [Re: fattire] #755611
07/23/10 07:43 AM
07/23/10 07:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the travel on the front... what rear suspension...
take video... its the only true way to see whats happening
Re: Tire rollout -Will I notice?? [Re: MR_P_BODY] #755612
07/23/10 08:22 AM
07/23/10 08:22 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i,d be lookin at thompson not the tires.
Re: Tire rollout -Will I notice?? [Re: MR_P_BODY] #755613
07/23/10 08:28 AM
07/23/10 08:28 AM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
Thompson doesn't prep their track on Wednesday nights. That has always been their "grudge night" where you race what ya brung. Kids show up in anyhing from their mommies Toyota to pick-up trucks dropping mud all over the track. I've pretty much given up on T&T'ing there.
Re: Tire rollout -Will I notice?? [Re: fattire] #755614
07/23/10 08:52 AM
07/23/10 08:52 AM
Locomotion Offline
Locomotion  Offline
You kind of answered you own question concerning traction.
Not all tracks are the same or prep the track the same. Some places cut back to save money. It's not an easy job for the tracks. I can go to an IHRA divisional or national event and unless there is an unusual, isolated situation on a particular run, I can pull the wheels on every run. I've been to local tracks where one day I hook every time and other days it spins half the time.
Rear tire rollout has minimal affect on traction. While a taller tire can actually have a little more surface contact with the track, it's certainly not enough to overcome major traction issues. A shorter tire can actually make them worse not only because of a little less contact surface, but because it would make the car think it has more gear ratio (numerically) which can aggrevate the situation.
Footbraking, carb tuning with the pump cam and squirters can help the car hook by getting the proper amount and duration of accellerator pump shot. If there are any lean or rich spots during the launch - 60', it can cause a dip in the application of power and unload the suspension enough, or not load it enough to begin with, to spin the tires.
But it looks like track conditions are more to blame, especially now in the summer with higher heat and humidity.
Re: Tire rollout -Will I notice?? [Re: Locomotion] #755615
07/23/10 10:22 AM
07/23/10 10:22 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
On my car I had to change the setup a lot to get the radials to work on a consistant basis. My rear shocks are set to full soft on both compression and extension. When the traction is really good in cooler weather I can tighten the compression some. I also have front coilovers and have been going to lighter and lighter front springs to store more energy. I also put the front of the ladder bars up a hole to hit the tire harder. These radials since they don't rinkle really need to be hit hard. Also put a little weight in the trunk. Hope some of this helps. I run the pro drag radials because when they hook they are deadly consitant so getting them to be happy every pass is the name of the game for me. Good luck.
14x Track Champ
Re: Tire rollout -Will I notice?? [Re: fattire] #755616
07/23/10 02:38 PM
07/23/10 02:38 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Here is a good program I found that can show you effect of tire size and staging depths, which I have found to be very accurate on my car: http://performancetrends.com/Drag_Race_Practice_Tree.htm
Re: Tire rollout -Will I notice?? [Re: Locomotion] #755617
07/23/10 07:32 PM
07/23/10 07:32 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Thats what I was looking for,I know they are good tires but want to go out and just race and have fun. I think the Hoosiers from what I have been told may be a little more forgiving on a track with poor prep. Want to set it and race.Just don't know how much 1/2 inch shorter tire will change things. Understand the size is a fitment issue not trying to solve the problem with tire size.
Re: Tire rollout -Will I notice?? [Re: fattire] #755618
07/23/10 10:15 PM
07/23/10 10:15 PM
Locomotion Offline
Locomotion  Offline
Around 1984 I bought a Challenger from a friend who had fabricated a home-made chassis and suspension for it. It ran fairly well and I was winning races, but it was not quite as consistent as thought it could be. Putting an extra 130 lbs in the trunk help consistency a lot and didn't slow it down much. (Just install it safely and securely, by the rules.)
Re: Tire rollout -Will I notice?? [Re: Locomotion] #755619
07/24/10 12:36 AM
07/24/10 12:36 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
The car is back halved and with the fuel cell not to much room back there. Wish I could get more movement out of the front, it seems like it spins before the front tries to do anything.
