Trans Refill with B&M Deep Pan #755346
07/22/10 04:30 PM
07/22/10 04:30 PM
N. ID
Blackmax Offline OP
Blackmax  Offline OP
N. ID
Anybody with B&M deep tranny pan on 727... how many quarts to refill trans after being drained for simple maintenance?
Re: Trans Refill with B&M Deep Pan [Re: Blackmax] #755347
07/22/10 04:34 PM
07/22/10 04:34 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Did you drain converter? If so , I THINK? 11-12 quarts"?" Start with 10 , then check.
Re: Trans Refill with B&M Deep Pan [Re: kidmopar] #755348
07/22/10 04:47 PM
07/22/10 04:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Start with 5qts and check. Normal maintaince doesn't drain the converter.
Re: Trans Refill with B&M Deep Pan [Re: stumpy] #755349
07/22/10 04:57 PM
07/22/10 04:57 PM
N. ID
Blackmax Offline OP
Blackmax  Offline OP
N. ID
I have one of those Lokar tubes with a plastic dipstick and it's hard to read fluid level. Like to get a reasonable idea so I don't over or under fill.
Re: Trans Refill with B&M Deep Pan [Re: Blackmax] #755350
07/23/10 02:47 PM
07/23/10 02:47 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
start with 5, then check it.. did you also get the filter extension for the deep pan?
Re: Trans Refill with B&M Deep Pan [Re: Dakota_Don] #755351
07/23/10 04:44 PM
07/23/10 04:44 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I change mine every 25 to 35 passes. It takes 7-1/2 quarts everytime.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Trans Refill with B&M Deep Pan [Re: Dakota_Don] #755352
07/24/10 01:30 AM
07/24/10 01:30 AM
N. ID
Blackmax Offline OP
Blackmax  Offline OP
N. ID
I have the deep extension. Seems to be about 9 to 10 quarts for refill but the FSM says 8 quarts for a stock pan and this pan is supposed to hold an additional 4 quarts so it has me worried that I'm not adding enough fluid. It's difficult to see fluid level on the Lokar stick.
