Help please..70 Dart trunk emblem #75483
06/18/08 02:46 PM
06/18/08 02:46 PM
St Louis MO
K
Keith C Offline OP
Keith C  Offline OP
K
St Louis MO
I have posted this on a couple A body sites and cant seem to get any answers. I am trying to find out how a 70 Dart trunk emblem is mounted. i am referring to the emblem that says Dodge in cursive writing that is one the passenger side of the trunk. Are there 4 holes drilled in the trunk for all 4 studs are there only two holes drilled and the other 2 are cut off? Also if all 4 do go in are do only 2 if them get nuts? Thanks for any help its greatly appreciated
Re: Help please..70 Dart trunk emblem [Re: Keith C] #75484
06/18/08 03:02 PM
06/18/08 03:02 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have the original emblem off mine and the trunklid is at the body shop. I can check it out the next time I go there to work on it.
I think the hood and trunk emblems look the same, but have a different stud count and the studs are in different places as well. Pretty sure the trunk has two and the hood has four off the top of my head.
Re: Help please..70 Dart trunk emblem [Re: Neil] #75485
06/18/08 03:55 PM
06/18/08 03:55 PM
Looked at mine, The trunk only has 2 posts with nuts. No more on it at all. The front has 3 across the bottom and 1 at the top of the D with nuts on all of them. They look the same but the studs are in different spots.
Re: Help please..70 Dart trunk emblem #75486
06/18/08 04:09 PM
06/18/08 04:09 PM
St Louis MO
K
Keith C Offline OP
Keith C  Offline OP
K
St Louis MO
Thanks Neil and WickedDart!!! I can rest my worried thoughts now
