How close is to close to Carb? #754190
07/21/10 09:03 AM
07/21/10 09:03 AM
Out West
408strokerdart Offline OP
Out West
I was wondering how close is to close for carb to hood clearance. I have a 1" spacer under my carb and it brings the carb real close to the hood scoop (6 pak type scoop). I was also wondering about the opening size in the scoop for a 417" engine spinning 8200 RPM. So the requirement of the engine is about 500 cu. ft./min of air. Does anyone think the close nature of the carb (1050 dominator) to the hood (about 1 1/2") is a problem? I have been considering going to a different hood scoop to give me more clearance to the carb.
Re: How close is to close to Carb? [Re: 408strokerdart] #754191
07/21/10 09:18 AM
07/21/10 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
From testing both Chrysler and myself, the top of the
carb should be 3/4" below the bottom of the scoop for
best performance... if the carb is up in the air flow
its causing turbulence plus if its way up in the air
flow its making the air go into shear to get into the
carb .... if you want to do a cheapo wind tunnel test
tape 2"-3" long pieces of yarn to all different places
in the scoop and mount a camera to the hood so you
can record the action of the stings
Re: How close is to close to Carb? [Re: MR_P_BODY] #754192
07/21/10 10:36 AM
07/21/10 10:36 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
...and mount a camera to the hood so you
OR...Mount the camera onto your brothers car facing rearward when you run him heads-up. Sorry, I saw it and I took the shot. J/K, I joke. I'm big on the string trick for scoop placement. Mike added valid criteria...below bottom of scoop base.
Re: How close is to close to Carb? [Re: 408strokerdart] #754193
07/21/10 10:36 AM
07/21/10 10:36 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Every time this comes up all I can say is look at the hemi super stockers...............the air horns are damn near touching the scoops and they run pretty good.
Re: How close is to close to Carb? [Re: MR_P_BODY] #754194
07/21/10 10:36 AM
07/21/10 10:36 AM
sg66mopar Offline
sg66mopar  Offline
Mr P, I'm guessing you mean 3-4 inches and not 3/4"? Mine's barely at 3" and I've wondered if that's too close.
Re: How close is to close to Carb? [Re: sg66mopar] #754195
07/21/10 10:44 AM
07/21/10 10:44 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've heard a minimum of 2" (I too have 1") and there is a theory based on throat size I think.
Re: How close is to close to Carb? [Re: sg66mopar] #754196
07/21/10 10:47 AM
07/21/10 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No... I said 3/4" below the BOTTOM of the scoop not
the top... by rights they say 3/4" below the bottom
of the intake of the scoop
Thumper they have rules to follow... look at pro stocks
they dont put those scoops on just for kicks... you
know are the PS guys are about aerodynamics
Re: How close is to close to Carb? [Re: MR_P_BODY] #754197
07/21/10 10:58 AM
07/21/10 10:58 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agree about the pro-stocks but the super-stockers are difinately making it work.
Re: How close is to close to Carb? [Re: MR_P_BODY] #754198
07/21/10 11:10 AM
07/21/10 11:10 AM
sg66mopar Offline
sg66mopar  Offline
Well, OK then.
Re: How close is to close to Carb? [Re: sg66mopar] #754199
07/21/10 11:47 AM
07/21/10 11:47 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have this old test done by Direct Connection for the snorkle scoops showing desired placement. they had found the previous style didn't work very well and came up with this design.this is the older scoop and lack of anything protruding out from the opening showed very little airflow into it.It might sound weird but I am using this on my Cuda.
home of the
Sox and Martin Hemi Duster
Re: How close is to close to Carb? [Re: HEMIFRED] #754200
07/21/10 12:46 PM
07/21/10 12:46 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i think the real point is this! sometimes you just got to do what you just got to do. like when the motor is set back and up high due to the car being low to ground.
Re: How close is to close to Carb? [Re: tjmarcus1] #754201
07/21/10 01:50 PM
07/21/10 01:50 PM
Out West
Out West
I will provide more detail. My carb sits pretty high, probably about 1" higher than the bottom of the scoop opening. I have the short 6-pak style AAR hood and my carb is sealed very well to the hood.
I have wondered if my scoop is arrowdynamically below the flow of air.
My carb is on a 1" HVH spacer that I could remove and try a couple of passes without it?
At this point, I just want it to run appropriate times for what it is. Not to concerned if I need another style of scoop, but don't want to do it if there is no gain there.
Re: How close is to close to Carb? [Re: HardcoreB] #754202
07/21/10 01:54 PM
07/21/10 01:54 PM
Out West
Out West
I think Lonnie will be looking at tail lights even if he is quicker than me
Actually, our cars are very well matched as they sit. I am looking to throw another .1 to .2 in the bank though.
Re: How close is to close to Carb? [Re: 408strokerdart] #754203
07/21/10 03:05 PM
07/21/10 03:05 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Easy schmeezy Japanesee.
Re: How close is to close to Carb? [Re: 408strokerdart] #754204
07/21/10 03:09 PM
07/21/10 03:09 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I know, you know, he knows, he ll we all know it.
Re: How close is to close to Carb? [Re: HardcoreB] #754205
07/21/10 05:28 PM
07/21/10 05:28 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've been wondering this too since the carb on my roadster is only about 1/2" from the hood without a hood scoop.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: How close is to close to Carb? [Re: HEMIFRED] #754206
07/21/10 07:54 PM
07/21/10 07:54 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I am looking for one of those windshield snorkle scoops for my Colt. Anyone?
