help with copper headgaskets #753846
07/20/10 09:46 PM
07/20/10 09:46 PM
Winterpeg, Canada
hvyweight Offline OP
Winterpeg, Canada
I have a B1MC 588 World alum engine and I am trying to source a copper head gasket .021 for 4.53 bore with the oring in the head measuring 4.80 on the outside diameter. I tried SCE website but can only find a 4.52 bore gasket. any ideas?
This is a nitrous motor?
Mike
Re: help with copper headgaskets [Re: hvyweight] #753847
07/20/10 10:05 PM
07/20/10 10:05 PM
Winterpeg, Canada
Winterpeg, Canada
no ideas?
Re: help with copper headgaskets [Re: hvyweight] #753848
07/21/10 12:03 AM
07/21/10 12:03 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I would call clark they should be able to make them for you.
.021 thickness? How far down is that piston? Steel rod needs around .039 piston to head and aluminum rod around .020 more.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: help with copper headgaskets [Re: hvyweight] #753849
07/21/10 02:45 AM
07/21/10 02:45 AM
Call SCE direct, they have made more than one custom Hemi head gasket for me, give them all the info you can They specialise in race gaskets of all types
Re: help with copper headgaskets [Re: bigtimeauto] #753850
07/22/10 04:42 PM
07/22/10 04:42 PM
Winterpeg, Canada
Winterpeg, Canada
The pistons is .010 in the hole. How far should the ID of the oring be to the gasket bore? The wire is protuding .010 out of the head.
