1953 coronet rear axle help #753715
07/20/10 06:54 PM
07/20/10 06:54 PM
Albany, NY
53hemi Offline OP
53hemi  Offline OP
Albany, NY
Hello - ok, heres the problem. My stock axle needs some tlc and its looks to be a bit pricey, not to mention I can't source adjustment shims. Has crossed my mind to go 8 3/4 but don't really want to lose my band brake. Thought about cutting the drive shaft ( a spare one ) and welding a yoke on to only one end. Am I crazy?
Re: 1953 coronet rear axle help [Re: 53hemi] #753716
07/20/10 07:43 PM
07/20/10 07:43 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Not the way I would go, but there's no reason it wouldn't work.
I've installed an 8-3/4 rear under the G/Friends 55 Desoto. An E-Body was a direct bolt in.
Re: 1953 coronet rear axle help [Re: SNK-EYZ] #753717
07/20/10 08:16 PM
07/20/10 08:16 PM
Albany, NY
53hemi Offline OP
53hemi  Offline OP
Albany, NY
What did you do on the transmission end? Did you retain the original tranny?
Re: 1953 coronet rear axle help [Re: 53hemi] #753718
07/21/10 03:00 AM
07/21/10 03:00 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
No, I installed a later model 904 Torqueflite so it has the later style slip yoke.
Re: 1953 coronet rear axle help [Re: SNK-EYZ] #753719
07/21/10 10:14 PM
07/21/10 10:14 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I don't see any reason you can't swap in a u joint end on your original drive shaft. The mid 60s Mopars have the tronion at the front and a u joint at the rear on most drive shafts during 64 & 65 when they were changing the transmissions from the cable shift to the rod linkage. Gene
