Changed Ignition needed bigger jets? #753159
07/20/10 08:32 AM
07/20/10 08:32 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I had a Mallory Dual point distributer with a Pertronics upgrade in it. Converted over to Mopar performance with a gold Box and plugs looked real lean had to jump jets from 76 to 88 in the rear. Is this common? I'm running VP110 and the plugs are just starting to look alittle gray.
Re: Changed Ignition needed bigger jets? [Re: flatiron] #753160
07/20/10 08:44 AM
07/20/10 08:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Jet for max MPH... thats seems like a big jump so
something wasnt right before
Re: Changed Ignition needed bigger jets? [Re: MR_P_BODY] #753161
07/20/10 08:52 AM
07/20/10 08:52 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I guess my worry is being new and just learning is going to big and washing down the cylinders. When you say MPH I take it you mean Mil per hour and not some other abbreviation. I don't have a weather station but Sunday here was very Humid and HOT how much of a role does this play in jet size?
Re: Changed Ignition needed bigger jets? [Re: flatiron] #753162
07/20/10 09:04 AM
07/20/10 09:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... MPH = mile per hour... temp and humidity have
a factor but jet it for the fastest MPH on the day your
testing... I will jet up or down 1 jet size for every
25* (if I feel like it to keep it optimized)... 1
jet size wont burn a piston if you were on before
Re: Changed Ignition needed bigger jets? [Re: MR_P_BODY] #753163
07/20/10 09:38 AM
07/20/10 09:38 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Why is it we can have things running pretty good but we just can't leave well enough alone.
Re: Changed Ignition needed bigger jets? [Re: flatiron] #753164
07/20/10 09:46 AM
07/20/10 09:46 AM
Az
Crizila Offline
Crizila  Offline
Az
It's our nature. My kids got me a T-shirt for Dad's day that reads " race it, break it, repair it, Repeat."
Fastest 300
Re: Changed Ignition needed bigger jets? [Re: Crizila] #753165
07/20/10 10:27 AM
07/20/10 10:27 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I would love to have that T shirt. Did they find it on the internet?
