Driveshaft Loop #752741
07/19/10 05:56 PM
07/19/10 05:56 PM
usa
mrmopardan Offline OP
usa
I'll post in this section first.. Does anyone make a bolt in D.S. loop that will fit a 68 GTX with TTI 3" full exhaust? Mancini say's the one they sell will not fit. Any suggestion?? As always, appreciate your input. Thanks
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: Driveshaft Loop [Re: mrmopardan] #752742
07/19/10 07:08 PM
07/19/10 07:08 PM
usa
usa
To better clarify, I'm referring to the drive shaft loops that bolt to the tailshaft cross member support.
Re: Driveshaft Loop [Re: mrmopardan] #752743
07/19/10 07:16 PM
07/19/10 07:16 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
The type of DS loop that attaches ONLY to the trans cross-member ....I myself would not use it.
I have seen one - and heard of another TWO - NOT contain a DS when the front U-joint failed.
Use a simple 30$ one that BOLTS into the floor.
Re: Driveshaft Loop [Re: mrmopardan] #752744
07/19/10 07:30 PM
07/19/10 07:30 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I have the U.S. Car Tool bolt onto the crossmember driveshaft loop on my 69 road runner.
Yes,I have 3in. dual exhaust.
Fits fine with zero problems.
Re: Driveshaft Loop [Re: jcastle1] #752745
07/19/10 08:29 PM
07/19/10 08:29 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Don't know if this will clear the exhaust but it is a bolt it.
http://www.metcomotorsports.com/products.asp?cat=96
Re: Driveshaft Loop [Re: mrmopardan] #752746
07/19/10 11:02 PM
07/19/10 11:02 PM
Under My Car
Mopar_Country Offline
Under My Car
Is this what your looking for?
http://www.uscartool.com/
