A-833 Bellhousing Pan & Shield Bolts- Painted? #75266
06/17/08 11:02 PM
06/17/08 11:02 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
Are the lower pan and front shield bolts on a late '70's A-833 O.D. bellhousing supposed to have their heads painted? Were the pan and shield painted after being bolted to the BH or before?
Also, what do the correct lower pan bolts look like?
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: In_The_Pink] #75267
06/18/08 08:47 AM
06/18/08 08:47 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The Bellhousing and shield were bolted to the engine before paint. Typically there was not too much paint towards the bottom of the cover but I have seen that area anywhere from 30 -90% covered in engine paint. The engine oil pans didn't get much paint on the bottom of them either. On small blocks I have seen the clutch fork rubber boot painted as well.
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: FJ5_Fish] #75268
06/18/08 10:12 AM
06/18/08 10:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bolts are
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: gtx6970] #75269
06/18/08 12:47 PM
06/18/08 12:47 PM
Milwaukee, WI
Milwaukee, WI
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: In_The_Pink] #75270
06/18/08 09:49 PM
06/18/08 09:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: Alaskan_TA] #75271
06/18/08 10:00 PM
06/18/08 10:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
two more from the same car ;
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: Alaskan_TA] #75272
06/18/08 10:01 PM
06/18/08 10:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: Alaskan_TA] #75273
06/19/08 12:10 AM
06/19/08 12:10 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
The bolt heads in the yellow survivor T/A "look" shorter than the ones gtx6970 posted. Are they shorter. I've heard of someone considering or did can't remember) grinding down the heads on their 4spd car.
Re: A-833 Bellhousing Pan & Shield Bolts- Painted? [Re: Alaskan_TA] #75274
06/19/08 07:58 AM
06/19/08 07:58 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
Nice pictures can you post some of the trans markings on a post I have open please. Thanks
This is the title under the restoration section
on page 2
"Anyone have orig. pics of paint dabs on a T/A 4spd case"
