Tubes vs NO Tubes ?? (Slicks) #752293
07/19/10 11:22 AM
07/19/10 11:22 AM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
What are you guys doing and why ?
I am sure there are different opinions,,,,
I "blew" up a tube this weekend at Martin,,,,,,just sitting in the PITS !
Brand new slicks,,,, (but the tubes were not)....
rim screws,,,,,
heard a huge BOOM,,,,,,,,then a hiss,,,,,,
tire was flat,,,,,pulled the tube out,,,and it ripped all the way around......lucky this didnt happen going down the track....
was able to get the tire mounted,,,to hold some air,,,,,,,
Now the side wall seems to be "bulging" out,,,and is touching (more like HITTING BIG TIME) on the inner wheel lip of the rear quarter,,,,,,was not doing that before,,,,,,
I have to pull both tires off and compare the thickness now,,to see if there is in fact a difference in the side wall bulge,,(ie,,,tire with tube,,,vs,,,tire without tube),,,or did something in the rear of the car move around,,,,
I have heard the tubes keep the side wall stiffer ? and the slicks will last longer ?
any downside to running tubes besides the cost ? ( and hassle ? )
thanks for any comments......
Re: Tubes vs NO Tubes ?? (Slicks) [Re: 69CHARGERMD] #752294
07/19/10 11:45 AM
07/19/10 11:45 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
this topic has been hashed around alot..
ill say if its a big tire car...most guys will tout the virtues of tubeless..
however if you on a spec slick (restricted from any big or wide sizes)
or just due to fitment..
TUBES have some attributes..
if these apply then you are a candidate for tubes
if you want the tire to grow at speed....diameter..
if you need a little more shock absorbtion from the hit..
if you have a heavy car on a smallish tire....
if you in northern us,canada or switzerland..and cold weather is a factor.....
if you are currently crushing your tires at the hit..
or have issues with tire folding/cupping at launch..
if you car wanders alot down track or at 2nd gear shift..(again with small tire..)
fwiw
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Tubes vs NO Tubes ?? (Slicks) [Re: cheapstreetdustr] #752295
07/19/10 11:53 AM
07/19/10 11:53 AM
KENTUCKY
KENTUCKY
31x10.5x15W MT
I put a pick of the car,,,you can see some tire wrinkle,,,this is with 14 lbs of air
Re: Tubes vs NO Tubes ?? (Slicks) [Re: 69CHARGERMD] #752296
07/19/10 12:04 PM
07/19/10 12:04 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've always ran tubes. With tubes they make the tire a little stiffer and the sidewall doesn't wear out as quickly. The down side is the weight of the tube may slow you down some, but I bracket race so a little bit of et isn't a big deal to me.
Re: Tubes vs NO Tubes ?? (Slicks) [Re: DusterKid] #752297
07/19/10 12:19 PM
07/19/10 12:19 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I know of lots of people that have had bad luck running tubes with slicks as you described .I personally am not running any in the 26x8.5x15 M/T's on my Dart,and have had no issues (other than one of them leaks down every week as did the old set).As far as the sidewalls wearing out without tubes, the last set on the car had over 100 passes on them and the sidewalls still looked like new IMO.About 30 passes on the current pair and same thing ,sidewalls still look great ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Tubes vs NO Tubes ?? (Slicks) [Re: The Shocker] #752298
07/19/10 01:19 PM
07/19/10 01:19 PM
KENTUCKY
KENTUCKY
I think i know what "could" have happened,,,,,
I am wondering if one of my wheel screws could have been showing thru the bead ?,,,,and it resulted in ripping the tube ?
Cant think of why else it would have blown like it did,,,,
I am going to stick a fresh set of tubes in it,,,,and put some washers on with the wheel screws ,,,just in case,,,,
Re: Tubes vs NO Tubes ?? (Slicks) [Re: 69CHARGERMD] #752299
07/19/10 01:54 PM
07/19/10 01:54 PM
western Ky
CraigS Offline
CraigS  Offline
western Ky
seems unlikely tire screw could penetrate through the bead,the bead is almost an inch thick where the screws go in.My screws dont stick 1/4 inch into the tire.
could the tube been twisted or otherwise installed in a pinch?
I run tubes so i dont have to constantly put air in the slicks.
my buddys tires (without tubes) go down on the rim overnight... what a drag.
Re: Tubes vs NO Tubes ?? (Slicks) [Re: CraigS] #752300
07/19/10 02:09 PM
07/19/10 02:09 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Were the tubes the right size for the slicks? If the tubes were too small for the slick they would have to be over inflated to fill the tire. That could cause a failure.
Getting old just means you were smarter than some and luckier than others.
Re: Tubes vs NO Tubes ?? (Slicks) [Re: CraigS] #752301
07/19/10 02:51 PM
07/19/10 02:51 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...If you will take Liquid Ivory dish washing soap, spread it generously all over the inside of the tire, it will seal the pores of the tire & it will hold air well. Plymouth Rocker told me this in ~ 2002. I applied it to my 22.5 Quick Time Pro's,(on the street), & never lost air. Of course there was those cold nights where the air in the tire shrank, but that's all. I'm not going to say it never ever leaked any thing but it works good. I did it for the NO hassle, & rotating weigh. I was in the process of putting a tube chassis,street car, in the 5's (1/8), on pump gas. I needed every ET I could get.
...The car's been setting for ~2 yrs now and still holding air. Plymouth Rocker is a racer & runs a tire store.
Re: Tubes vs NO Tubes ?? (Slicks) [Re: thehemikid] #752302
07/19/10 05:11 PM
07/19/10 05:11 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
there were two important things I didn't notice
getting any mention.
BABY POWDER a whole can goes into the pair when I mount with tubes. stops sticking and reduces wear and tears,
where the natural rubber tubes ? no others work
home of the
Sox and Martin Hemi Duster
Re: Tubes vs NO Tubes ?? (Slicks) [Re: 69CHARGERMD] #752303
07/19/10 05:34 PM
07/19/10 05:34 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I would inspect the inner sidewalls for anything suspisious before moving on. Something may have happened to the tire that caused the issue with the tube.
I run tubes always have and like HEMIFED said use lots of baby powder.
Re: Tubes vs NO Tubes ?? (Slicks) [Re: roadhazard] #752304
07/19/10 06:59 PM
07/19/10 06:59 PM
same thing happened to me, replaced the tube 3 times only to find out there was a small piece of metal, very small on the inside of the slick, pull your slick off and find the small nail or metal.
Re: Tubes vs NO Tubes ?? (Slicks) #752305
07/19/10 08:06 PM
07/19/10 08:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No tubes for me. My hoosiers hold air all winter without tubes. Ron
Re: Tubes vs NO Tubes ?? (Slicks) [Re: 69CHARGERMD] #752306
07/19/10 08:51 PM
07/19/10 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug when I threw out that tube I dont recall seeing
any baby powder on it or smelling it.... who mounted
them
Re: Tubes vs NO Tubes ?? (Slicks) [Re: MR_P_BODY] #752307
07/19/10 09:12 PM
07/19/10 09:12 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
them
I have absolutely no problems with that!
Re: Tubes vs NO Tubes ?? (Slicks) [Re: Fast Yeti] #752308
07/19/10 09:19 PM
07/19/10 09:19 PM
central ohio
N
nss guy Online happy
nss guy  Online Happy
N
central ohio
Bias slicks I run tubes with a TON of baby powder.
Radials are tubeless.
Re: Tubes vs NO Tubes ?? (Slicks) [Re: nss guy] #752309
07/19/10 09:25 PM
07/19/10 09:25 PM
KENTUCKY
KENTUCKY
Mike,
your correct,,,there was "some" baby powder on the tube,,,but not much,,,,
I think im getting a rash from lack of powder,,,lol
Re: Tubes vs NO Tubes ?? (Slicks) [Re: HEMIFRED] #752310
07/19/10 09:34 PM
07/19/10 09:34 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
BABY POWDER . stops sticking and reduces wear and tears,
home of the
Re: Tubes vs NO Tubes ?? (Slicks) [Re: 69CHARGERMD] #752311
07/19/10 09:36 PM
07/19/10 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike,
When the tire gets hot the tube tends to stick to the
tire without plenty of baby powder/talc... then when
the tire raps up it pulls pretty hard on the tubes
Re: Tubes vs NO Tubes ?? (Slicks) [Re: MR_P_BODY] #752312
07/20/10 06:53 AM
07/20/10 06:53 AM
KENTUCKY
KENTUCKY
so i assume whoever mounts them,,,should put lots and lots of powder INside the slick,,,and ON the tube as well....
