Carter AVS Question #75224
06/17/08 08:57 PM
06/17/08 08:57 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
What's the difference between a low performance AVS and a high performance AVS? Is it maybe just jetting and squirters? Would it relatively easy to upgrade to a HP?
Thanks!
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Carter AVS Question [Re: Hrtbkr] #75225
06/17/08 09:31 PM
06/17/08 09:31 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
There are 2 sizes, smaller was used on 340, 383 and non-hp 440. 440 hp used the bigger AVS, and it has bigger primary bores. The secondary side is the same size between the two. You obviously can't turn a small one into a big one, but playing with the jets and metering rods, you can fatten up either one.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
