Blue Voltage Regulator -constant output -no good???
#752008
07/18/10 10:34 PM
07/18/10 10:34 PM
Posts: 137 Kenosha, WI wi/il border
BobN
have 68 Coronet ,put Mopar Electric ignition conversion in. Was told to change to Mopar Blue Voltage Regulator (constant output) for system to work right. Now I have been told that these can smoke your system or battery.So what do I use for regular that runs the electric ing system?? someon said Year One has a modern electric type regular but in older style look for such conversions. WhAT DO OTHERS RUN??? dO THE BLUE CONSTANT OUTPUT REGULATORS CAUSE ISSUES????
Re: Blue Voltage Regulator -constant output -no good???
[Re: BobN]
#752009
07/18/10 11:32 PM
07/18/10 11:32 PM
RapidRobert
Cant ans your Q directly, some have used them w no issues but the output does not fall off as temp increases which it should in a non race app. Someone in one of the parts for sale sections here has (or had) an OE appearing one w the black cover w electronic guts for #25 to your door and your parts house has a wells iirc VR706 which is electronic but slightly different from OE appearance. I would go w one of these rather than a constant (voltage) output model.
[Re: BobN]
#752010
07/19/10 01:05 AM
07/19/10 01:05 AM
Posts: 415 Indiana
Pentastar440
Indiana
Why not convert to electronic voltage regulator?
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: Pentastar440]
#752011
07/19/10 01:43 AM
07/19/10 01:43 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
there are elect regulators blue ( race ??? )boxes too.
[Re: 68LAR]
#752013
07/19/10 10:37 AM
07/19/10 10:37 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Just go to any good parts store and get the reg that looks almost like OE and hooks up just like the points reg.Had them in 3 cars and one still has it.Been in for 11 years and no problems no wires to splice etc.It just bolts in.Most parts store dont even have the old points style now.Ive heard of people running the blue MP ones.But it could overcharge.Rocky
Chrysler Firepower
[Re: GoodysGotaCuda]
#752018
07/20/10 10:25 AM
07/20/10 10:25 AM
NachoRT74
Valencia, España
ok, for those using the blue boxes ( single or dual field ) do you actually use your car a s driver, or at least reguraly ?
how's your ammeter reading ? ( if you have it hook )
[Re: NachoRT74]
#752019
07/20/10 10:44 AM
07/20/10 10:44 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes regularly. I kissed my ammeter goodbye a long time ago after it started smoking behind my dash...
My autometer voltmeter reads just fine. I'm running about 13v at idle with the fan on. 14.5v or so buzzing down the road.
#752020
07/20/10 04:59 PM
07/20/10 04:59 PM
NachoRT74
Valencia, España
well... I'm interested on ammeter more than volts, due amperes is what can overcharge the batt, getting leaks and vapors around
[Re: BobN]
#752025
07/21/10 07:29 AM
07/21/10 07:29 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I ran the blue one on the street for a couple of years without any problems, until recenctly. The last couple of years I have not driven the car in the rain or at night but lately I have been working on getting the wipers and the headlights working correclty. I was idling the car in my driveway (in D with emerg brake applied for carb tuning) with my lights on and heard my idle rpms drop and the engine started shaking. The first thing that I looked at was the coil voltage inside of the car on my gage and it dropped down below 12v. As soon as I turned the lights off the coil voltage came back up and the idle came back up and it was idling fine. What I found out was since I was running the constant output regulator and I was applying more load at the in D idle rpms, the constant output regulator was not compensating for the extra load. I bought a NAPA brand voltage regulator and I have not had this problem since and my average system voltage has gone up to handle the extra voltage loads. My experience with the blue regulator shows me that it was fine on the street for a couple of years and not using any extra voltage loads. But know since I need to use some of the accessories I now need to use the standard compensating regulator.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
