Do you have a restrictor in your thermostat housing? #751901
07/18/10 09:37 PM
07/18/10 09:37 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I am running a Moroso ele water pump on my 360. So I do not have a thermostat in. I was told the water is cycling thru to fast and I need to make a restrictor. Any input on this?
Re: Do you have a restrictor in your thermostat housing? [Re: flatiron] #751902
07/18/10 09:40 PM
07/18/10 09:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, one's in mine - 368" SB, Moroso pump - don't recall the hole size though.
Re: Do you have a restrictor in your thermostat housing? [Re: flatiron] #751903
07/18/10 09:43 PM
07/18/10 09:43 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Who told you that? Restrictors are used to control cooling by limiting coolant circulation. Under no circumstances will adding a restrictor ever result in more efficient heat transfer.
Re: Do you have a restrictor in your thermostat housing? [Re: topside] #751904
07/18/10 09:43 PM
07/18/10 09:43 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Did it help with your heating problems? How was it made is it round and fit were the thermostat goes or is the same shape as the bottom of your housing?
Re: Do you have a restrictor in your thermostat housing? [Re: flatiron] #751905
07/18/10 09:45 PM
07/18/10 09:45 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
I run a t-stat with the guts cut out.
Re: Do you have a restrictor in your thermostat housing? [Re: abodiesonly1] #751906
07/18/10 09:55 PM
07/18/10 09:55 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Did it seem to make a difference?
Re: Do you have a restrictor in your thermostat housing? [Re: abodiesonly1] #751907
07/18/10 09:56 PM
07/18/10 09:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here............
Re: Do you have a restrictor in your thermostat housing? [Re: Thumperdart] #751908
07/18/10 10:10 PM
07/18/10 10:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine's a round disk with a hole in it; was in the car when I got it, and haven't messed with it yet.
The idea is to keep the water in the radiator longer so it rejects more heat; obviously the other side of the equation is keeping the water in the motor too long and having more heat to reject.
With iron heads, my car ran quickest/fastest with 120-degree water, (warm oil); I honestly don't know what the current aluminum heads on it want, but I haven't experimented with that yet.
Re: Do you have a restrictor in your thermostat housing? [Re: flatiron] #751909
07/18/10 10:10 PM
07/18/10 10:10 PM
Great Lakes Region
Great Lakes Region
I just think by having some type of restrictor in there slows the flow enough to allow the water flowing thru the radiator to cool a bit longer.
Re: Do you have a restrictor in your thermostat housing? [Re: abodiesonly1] #751910
07/19/10 09:13 AM
07/19/10 09:13 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
May seem that way but that is not the case with a closed loop system. The only benefit of using a restrictor is to keep heat in the motor. You might ask yourself what a thermostat does? It opens as the coolant gets warmer thus allowing more flow. When the coolant is at it hottest temp the thermostat is wide open. So...how can using a restrictor-which impedes flow actually make your cooling system more efficient? Answer? It doesn't but there are some who will continue to hang onto this myth.
Re: Do you have a restrictor in your thermostat housing? [Re: BobR] #751911
07/19/10 12:19 PM
07/19/10 12:19 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
The biggest reason I can see to run a restrictor would be to keep the amp draw down on the pump..a pump like this will pull more amps with more flow...wide open may electrically stress the pump motor.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Do you have a restrictor in your thermostat housing? [Re: abodiesonly1] #751912
07/20/10 12:14 AM
07/20/10 12:14 AM
Pittsburgh, PA
SmokeyBurnout 67 Offline
Pittsburgh, PA
AGREED!- We run a gutted T-stat and it's perfect. We also run ours on the street and have raced with a 180 stat and it was no good for consistancy, then without a stat just to try, again no good- the water couldnt cool quick enough. I strongly suggest a gutted T-stat.
Kara
Re: Do you have a restrictor in your thermostat housing? [Re: SmokeyBurnout 67] #751913
07/20/10 01:00 AM
07/20/10 01:00 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
i run a 160 thermostat with just a 1/8" hole drilled in it, dont know if its right or wrong but it works for my set up, car hasnt got hot yet at the strip or street
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Do you have a restrictor in your thermostat housing? [Re: flatiron] #751914
07/20/10 03:44 AM
07/20/10 03:44 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I ran a radiator shop for a few years...and fixed many a cooling problem.
A restrictor does not help cooling...at best you gain nothing. Think of it this way..Unrestricted, the water will flow through the radiator more times per hour...increasing cooling. Restricted, it goes through the rad less times per hour, reducing cooling. Yeah it might spend a bit longer time in the radiator, but thats nothing compared to the water flowing through the radiator several times more per hour.
Read this:
http://www.stewartcomponents.com/tech_tips/Tech_Tips_3.htm
Re: Do you have a restrictor in your thermostat housing? [Re: Quicksilver440] #751915
07/20/10 04:35 AM
07/20/10 04:35 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
"A common misconception is that if coolant flows too quickly through the system, that it will not have time to cool properly. However the cooling system is a closed loop, so if you are keeping the coolant in the radiator longer to allow it to cool, you are also allowing it to stay in the engine longer, which increases coolant temperatures. Coolant in the engine will actually boil away from critical heat areas within the cooling system if not forced through the cooling system at a sufficiently high velocity. This situation is a common cause of so-called "hot spots", which can lead to failures."
Isnt that what a tstat does anyway ....
Mopar Performance
Re: Do you have a restrictor in your thermostat housing? [Re: flatiron] #751916
07/20/10 07:46 AM
07/20/10 07:46 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
no stat and stays at 145*..real secret is a large radiator preferably a dual pass with about 4,000+ CFM of air movement thru it....thats whats in the race car
my street car I use a 160* stat and it stays mostly in the 180-190* area...it has a crapola Be-Cool radiator that is to small for a blower engine..as soon as I get rich Im swapping it out for a dual pass and one of those Taurus 2 speed fans...those pull 4,000CFM and are so much cheaper than Spals which I have 4 on it already...sucks dont it...
