in progress turbo duster #751836
07/18/10 09:17 PM
07/18/10 09:17 PM
Brunswick Ohio
dusta340 Offline OP
dusta340  Offline OP
Brunswick Ohio
i already made headers but i was not happy with them and i went to a motor plate. i am going to run a a/w intercooler in car.
engine is a
mopar r3 48*
custom comp solid roller cam
eagle crank and rods
custom wisco pistons coated 9 to 1
indy 360-1 heads ported by bob here at big 3 flow 325 cfm
turbo is a 88mm s480 borg warner
twin turbonetic 35mm wastegates
procharger race bypass valve
goal is 1000 whp
Re: in progress turbo duster [Re: dusta340] #751837
07/19/10 11:33 AM
07/19/10 11:33 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Could you resize those pics to keep them under 750 pixles wide?
- Stu Harmon
