495 stroker spark plugs #751693
07/18/10 07:57 PM
07/18/10 07:57 PM
High Ridge MO.
MOPARCHAS Offline OP
High Ridge MO.
what is the spark plug of choice
495 Indy S/R heads ported and flowed to max wedge size on gas 13.7 to 1 compression
thanks
Re: 495 stroker spark plugs [Re: MOPARCHAS] #751694
07/18/10 09:22 PM
07/18/10 09:22 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
I run something similar to your setup, only about 12.7:1 and with Indy EZ's and have had very good luck with Autolite AR3934's gapped to .035
65' Belvedere
496'' Stroker
Indy Heads
Re: 495 stroker spark plugs [Re: belvedere383] #751695
07/18/10 09:47 PM
07/18/10 09:47 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
AR51
Re: 495 stroker spark plugs [Re: MOPARCHAS] #751696
07/18/10 09:52 PM
07/18/10 09:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
C59CX or C57CX as per Indy!!!
Re: 495 stroker spark plugs [Re: MOPARCHAS] #751697
07/19/10 12:59 AM
07/19/10 12:59 AM
I like the Autolite 3910, if you try them make sure and check the extendedplug tips to pistn domes for cantact before racing it
