f-body od 4 speed trans. #751519
07/18/10 05:41 PM
07/18/10 05:41 PM
new york
desotoman Offline OP
new york
i picked up a od 4 speed trans.it's the 1970 and up with 2 shifter mounting tabs the shifter is hooked up on the foward location,it was in a 1970 road runner,will this fit in my f-body car?
Re: f-body od 4 speed trans. [Re: desotoman] #751520
07/18/10 05:52 PM
07/18/10 05:52 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I believe that fits a B or E body only. The A and F body manual transmissions are the same.
Re: f-body od 4 speed trans. [Re: desotoman] #751521
07/18/10 09:00 PM
07/18/10 09:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That transmissions was likely out of a 70's/80's dodge van or 2wd truck originally, which used the same transmission length as the B/E body cars. A/F body used a shorter tail shaft. With some modding you can put a b/e trans in an a/f body.
