70-72 "A" Engine Valve Cover 3 Digit Code Inquiry #751203
07/18/10 01:15 PM
07/18/10 01:15 PM
Morningside, Long Island
scatcity Offline OP
scatcity  Offline OP
On Hamtramck E body vehicles I'm curious to know if the left valve cover should have a 3 digit bin code towards the front of it as typically found on "B" & "RB" engines. If so, what are some of the more common numbers floating around out there for 70-71 340's ? I'm sure there are quite a few variables regarding this subject not only from plant to plant, including but not limited to shift, gate, which line, etc., etc. Thanks regarding, Tommy
Re: 70-72 "A" Engine Valve Cover 3 Digit Code Inquiry [Re: scatcity] #751204
07/18/10 01:18 PM
07/18/10 01:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I've seen a couple original road tests of 70/71 340's in demons /dusters. in those pics i did not see any crayon marks on the V/c's
