transmission flex plate #751159
07/18/10 12:30 PM
07/18/10 12:30 PM
michigan
bighughey Offline OP
michigan
i am trying to put together my 505 stroker. the crank is an eagle stroker and the flexplate that i have doesnt match up to the bolt holes.my flywheel is made onto my convertor
Re: transmission flex plate [Re: bighughey] #751160
07/18/10 02:11 PM
07/18/10 02:11 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
how many holes does the flexplate have at the crank?
and how many holes are drilled and tapped on the crank flange?
Tony
70 AARCuda Vitamin C
Re: transmission flex plate [Re: 70AARcuda] #751161
07/18/10 02:29 PM
07/18/10 02:29 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It will only fit one way so you need to rotate it until the holes line up.
Re: transmission flex plate [Re: 70AARcuda] #751162
07/18/10 08:13 PM
07/18/10 08:13 PM
michigan
michigan
hey tony.there is like 10 bolt holes at the crank. i think the flexplate that the trans shop sold me is too small.it bolts up to the converter but the bolt pattern is smaller than the bolt pattern on the crank. so im thinking that the flexplate is for a stock 440.i tried to look up flexplate on summit but it only shows a flywheel.do they call it something else?any help would be greatly appreciated.been thying to build this car for 10 years.finally got rid of the wife and have the money to put it together.lol
Re: transmission flex plate [Re: bighughey] #751163
07/18/10 08:53 PM
07/18/10 08:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds like you have an 8 bolt flange on the crank. Eagle sells 6 and 8 bolt flange cranks, and the matching flexplates are easily obtainable.
Re: transmission flex plate [Re: buildanother] #751164
07/18/10 10:12 PM
07/18/10 10:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
b&m makes an 8 bolt flexplate.....
I figured you had too many holes...LOL
Tony
Re: transmission flex plate [Re: 70AARcuda] #751165
07/19/10 06:28 AM
07/19/10 06:28 AM
michigan
michigan
hey thanks tony.thats what itis.gonna call summit today and order the right one.
