Re: LA Small Block Timing Chain ???
[Re: way2fast]
#751137
07/18/10 12:08 PM
07/18/10 12:08 PM
Posts: 15,487 Florida
scratchnfotraction
IIRC,yes the 90 roller cam will be a short nose cam IIRC the t sprocket is a diff thickness and has a diff washer bolt set up have them pull the 2 off the shelf and compair them
[Re: scratchnfotraction]
#751138
07/18/10 12:23 PM
07/18/10 12:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I don't think so, it isn't until the Magnum 318 came out that the roller cam changed. And I don't believe that happened till 91.
If it's still an LA 318 then it still uses the same timing set. Looke at the valve cover bolts, 5 means LA, 10 means Magnum (per cover).
[Re: way2fast]
#751142
07/18/10 03:44 PM
07/18/10 03:44 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
It's definitely a LA motor with a roller cam not a magnum motor....but I questioned the timing set because the flat tappet hydraulic cam timing sets look different than what I took off my roller cam motor. So I'm guessing they are def different and I can't just get a regular double roller to fit, it has to be Roller cam specific??.
Timing events are the same and they do interchange- I took a low miles double roller set that was from my 340 engine back in the 80's and just installed it on my 1994 5.9 Magnum engine.
I checked the cam timing events, everything was the same.
