How do you get hard water stains off your paint? #751120
07/18/10 11:11 AM
07/18/10 11:11 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Our water here really sucks, and it will leave hard water stains where every a drop will dry, even in the shade. Does anybody have any ideas on how to get these off my RR. i tried windex, and wax, neither worked so far. I just don't want to damage the paint, trim, or wheels in the process.
Re: How do you get hard water stains off your paint? [Re: NV69B7RR] #751121
07/18/10 11:19 AM
07/18/10 11:19 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had got some off in the past with a clay bar..
Re: How do you get hard water stains off your paint? [Re: OzHemi] #751122
07/18/10 11:48 AM
07/18/10 11:48 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Now if I could find something to get rid of the spots on Glass and the spider webs that show up on black paint.
Re: How do you get hard water stains off your paint? [Re: Cudajon] #751123
07/18/10 11:54 AM
07/18/10 11:54 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Bon Ami' on glass...
(or 0000 fine steel wool )
Re: How do you get hard water stains off your paint? [Re: OzHemi] #751124
07/18/10 01:29 PM
07/18/10 01:29 PM
St. Leonard
Curt Hildebrandt Offline
St. Leonard
I use Griot's Garage Speed Shine and there Caly bar....In fact, I do my Whole Ramcharger...Takes thewater spots off paint and glass..
Re: How do you get hard water stains off your paint? [Re: NV69B7RR] #751125
07/18/10 04:58 PM
07/18/10 04:58 PM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
Another thing that works is Vinegar and Distilled water mixed 50/50. Be aware it also strips the wax off too.
69 Roadrunner 383 stock
Re: How do you get hard water stains off your paint? [Re: NV69B7RR] #751126
07/18/10 05:30 PM
07/18/10 05:30 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
We have hard water here too, and I just finished the black paint on my 1970. Water spots galore on all my cars until I started doing this.
There are a few things you can do, but the bottom line is to do your final rinse with de-mineralized water. From my experience, the spots dissolve almost immediately in water.
The least expensive way is to buy several gallons of distilled water from the market, and pour it over your car when your finished washing.
Second option, buy a Hudson Sprayer style garden sprayer. Fill it up with the gallon jugs of distilled water and final rinse the car with that. You know, the kind with a plastic tank that you pump up and spray weeds and such with. Use it only for rinseing your car, so it won't get contaminated.
If you don't want to keep lugging home gallon jugs, have a home-use reverse-osmosis system installed in your house or install it yourself. The added benefit is great drinking/cooking water etc. You can buy a good one from Costco.
This last idea is initially the costliest, but one of the best. Hook one of these up to your house/garage.
http://www.costco.com/Browse/Product.asp...&lang=en-US
They say if you plumb the water from your Reverse Osmosis water system into one of these systems, it will last 25 times as long. You will probably need to add a second larger pressure tank to feed it effectively though.
Re: How do you get hard water stains off your paint? [Re: NV69B7RR] #751127
07/19/10 09:47 AM
07/19/10 09:47 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Meguiars speed glaze # 80 takes it right off I use show car glaze after the #80 and the paint is clean and water spots are gone then a good carnuba wax. I use a towel and the wax on wax off system I don't trust myself with a buffer. Keep it waxed and the water spots won't stick again they just wipe off. On the windows use rubbing compound ( the finest you can find from schucks or autozone) then rain X after the windows are clean to keep the water spots from sticking again. I hate water spots and it took me a long time to figure out a system that works. A tip on using glaze don't let the glaze dry like you would wax wipe it off before it hazes and it make the a lot job easier.
Re: How do you get hard water stains off your paint? [Re: Boise Chall] #751128
07/19/10 10:27 AM
07/19/10 10:27 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
I had an idea once to take one of these...
and fill it with some of this...
i havnt tried it yet, but it is supposed to prevent water spots on your dishes right? so why wouldnt it prevent them on your car?
Re: How do you get hard water stains off your paint? [Re: Boise Chall] #751129
07/20/10 12:59 PM
07/20/10 12:59 PM
Cincinnati, OH
68red440 Offline
68red440  Offline
Cincinnati, OH
Last spring #80 easily took off sun-baked contaminants like water spots, sap etchants, bird poop etched in, etc. And it's really easy on the paint.
I tried #7 last weekend. I applied it to the whole car and it dried up - not fun to remove. NXT wax & #7 gave excellent results though.
Re: How do you get hard water stains off your paint? [Re: Boise Chall] #751130
07/20/10 03:34 PM
07/20/10 03:34 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I really like the Meguires product and of all things, turtle wax has a good carnauba cleaner wax too that works well.
Re: How do you get hard water stains off your paint? [Re: NV69B7RR] #751131
07/20/10 08:17 PM
07/20/10 08:17 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Either use a chamois or as I do a leaf blower to dry it and it won't leave any marks. Also make sure it is cleaned and waxed often.
Re: How do you get hard water stains off your paint? [Re: JonC] #751132
07/21/10 09:53 AM
07/21/10 09:53 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks for the replies, I'll be putting them to good use shortly!
