71-74 B-body 8 3/4 rear end question #750756
07/17/10 08:25 PM
07/17/10 08:25 PM
Pennsylvania
craigerlitz Offline OP
Pennsylvania
Is there a difference between 71-72 and 73-74 housings? I have two that have the same major measurements, but have a different appearance.
Re: 71-74 B-body 8 3/4 rear end question [Re: craigerlitz] #750757
07/17/10 08:28 PM
07/17/10 08:28 PM
Pennsylvania
Pennsylvania
Here is the second end. It has a much larger opening at the spring perch. Also the one part coming from the flange is only half as long as on the other one.
Thanks,
Craig
Re: 71-74 B-body 8 3/4 rear end question [Re: craigerlitz] #750758
07/17/10 08:50 PM
07/17/10 08:50 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
73/4 use a rubber isolator.
Re: 71-74 B-body 8 3/4 rear end question [Re: rrunner] #750759
07/17/10 09:34 PM
07/17/10 09:34 PM
canada
mridolfo Offline
mridolfo  Offline
canada
The second one is for a 73/74 body. The larger hole is for the rubber isolator.
Re: 71-74 B-body 8 3/4 rear end question [Re: mridolfo] #750760
07/17/10 09:58 PM
07/17/10 09:58 PM
Pennsylvania
Pennsylvania
Thanks everyone. I should have known that.
Thanks,
Craig
Re: 71-74 B-body 8 3/4 rear end question [Re: mridolfo] #750761
07/18/10 01:39 PM
07/18/10 01:39 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and I am PRETTY SURE for several reasons the 73/74 perche is lower due the added height by the isolators and clamps assembly
I know lot of ppl will tell NO, but still... after try to fit a 71/72 sway bar plate on my 74, after fill the step to fit on isolator clamp, the plate didn't fit ATTENTION, DIDN'T FIT on my car because plate was meeting with axle housing. 73/74 plate has a very diff slope shape on plate on the tab area going to the rod to sway the axle housing
