Vin # Locations 71 B Body? #750601
07/17/10 06:51 PM
07/17/10 06:51 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Where are the numbers on a 71 B Body? Thanks!
Re: Vin # Locations 71 B Body? [Re: 68GTS383] #750602
07/17/10 07:30 PM
07/17/10 07:30 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Let's see, off the top of my head... ...Driver's door sticker, dash vin tag, fender tag, build sheet in the interior....Partial on engine, trans, cowl driver's side under fender near cowl seal, rad support driver's side along side upper rad mounts...Possibly under the trunk seal...OK guys did I miss any ???
Re: Vin # Locations 71 B Body? [Re: screamindriver] #750603
07/17/10 08:29 PM
07/17/10 08:29 PM
Title and registration. Sometimes the insurance card...
Re: Vin # Locations 71 B Body? #750604
07/17/10 08:39 PM
07/17/10 08:39 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
cowl spot is diff than e body
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Vin # Locations 71 B Body? [Re: screamindriver] #750605
07/18/10 01:46 PM
07/18/10 01:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
below rear package tray, at the very end driver side corner... there is a plate similar to a fender tag there
at least mine ( what it wasn't assemblied in USA )
Re: Vin # Locations 71 B Body? [Re: NachoRT74] #750606
07/18/10 02:38 PM
07/18/10 02:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
On a 1971 B-body the drivers side radiator core support and drivers side cowl are the only areas of the body that were stamped with a VIN sequence #.
Re: Vin # Locations 71 B Body? [Re: ScottSmith_Harms] #750607
01/19/11 09:34 PM
01/19/11 09:34 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
No where in the rear?
Re: Vin # Locations 71 B Body? [Re: DANA60] #750608
01/20/11 12:12 AM
01/20/11 12:12 AM
Alabama
BigMoneyLewis Offline
Alabama
No rear stamping on the trunk rail on 71-up B body .
The only two BODY stampings, as mentioned above, are on the rad support and the cowl under the weatherstrip.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Vin # Locations 71 B Body? [Re: BigMoneyLewis] #750609
01/20/11 04:30 PM
01/20/11 04:30 PM
Nanaimo, BC
N
NOrrTH Offline
NOrrTH  Offline
N
Nanaimo, BC
Where EXACTLY on the rad support is it? I cant find mine. Is it on the radiator side on the front of the horizontal piece or is it on the drivers side rad facing vertical support?
Also, mine was definitely 'stamp missed" on the cowl unless the stamping was so light a light coat of paint filled it.
Cheers
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: Vin # Locations 71 B Body? [Re: NOrrTH] #750610
01/20/11 04:49 PM
01/20/11 04:49 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Cheers
My body shop primed and blocked/sanded the whole car before shooting it. When it was done, I could barely make out the trunk rail stamping so I made them strip it and paint it without sanding.....still isn't as visable as I would like.
It may be different on your '71, but my '70 rad support stamping is on the horizontal bar, towards the drivers side, facing the radiator.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Vin # Locations 71 B Body? [Re: NOrrTH] #750611
01/20/11 06:01 PM
01/20/11 06:01 PM
Alabama
Alabama
Cheers
How early was your car, and what assembly plant ?
My St . Louis Built '71 GTX RS23U1G100327 which had an 803 SPD did not get a cowl stamp either . This was an unrestored survivor car I owned a few years back.
Greg
Re: Vin # Locations 71 B Body? [Re: BigMoneyLewis] #750612
01/20/11 08:29 PM
01/20/11 08:29 PM
Nanaimo, BC
N
NOrrTH Offline
NOrrTH  Offline
N
Nanaimo, BC
Cheers
Greg
Door jam decal Sept 1970
Windsor Ontario
RS23U1R11816*
Re: Vin # Locations 71 B Body? [Re: NOrrTH] #750613
05/15/11 10:56 PM
05/15/11 10:56 PM
Illinois
SGTFURY62 Offline
SGTFURY62  Offline
Illinois
I was wondering the same thing for my 71 GTX. My radiator support had been cut out and replaced at some point with a removable bolt in section from a different car. Was told original support was trashed when engine pulled and fell on it. I am trying to verify rest of body numbers but haven't found any. I've searched high and low and have even sanded down areas on cowl to find numbers but have come up with nothing. I found some really small part numbers stamped on cowl area but nothing resembling a partial vin???? Any place else to look?
