(First of all, I didn't remove it...)
I have a 340 +6 (AAR Cuda)
Note: I have a big cam with long duration.... and have virtually no vacuum at idle (9")
It was originally running very very rich and fouling out plugs within minutes... My guess is that I had the wrong size PV...and was open at idle.
A friend of mine looked at the center carb, and said I should remove the PV....and he replaced it with a block off....
He then upjetted to compensate for the lack of the power valve....
That actually fixed the problem of running Rich and fouling plugs, but here's my current problem...which I think may be the side effect of a missing power valve.
Sluggish off the line
Backfires and pops under heavy acceleration (usually means LEAN mixture)
Runs ok after a few seconds of full throttle...but still a few pops...
My theory is that I need a (4") PV (half of vacuum reading at idle), but here are my questions:
1.) What is the side effect of having it blocked off ?
2.) How much fuel (percentage) does the PV add under full throttle ? (10% - 30%) etc..?
My timing is set at 20/36 and all in at 2500... (probably a little early) ?
Thanks for any advice.
Im all ears.
