installing new seat covers #75027
06/17/08 03:11 PM
06/17/08 03:11 PM
Anonymous OP
Anonymous OP
when installing new seat covers , can you leave the old cover on and put it over the top or do you have to remove the old one? tks larry
Re: installing new seat covers #75028
06/17/08 03:18 PM
06/17/08 03:18 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Remove the old covers first...and leave the new ones out in the sun for a while to soften them up, and make them easier to install
Re: installing new seat covers [Re: OzHemi] #75029
06/18/08 10:42 AM
06/18/08 10:42 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Make sure you reuse the wires that are hog ringed to the frame to pull down your pleats. If they are real rusty- I sometimes just reproduce them with coat hanger wire. Without these- your covers will look like crap. Loose saggy etc. Are your seat foams in good shape? If not you can add padding, which is easy to do- but hard to make look perfect without some experimentation/experience. Buying the new foams is a wise move in my opinion. Kirby
Re: installing new seat covers [Re: Kirby] #75030
06/18/08 12:00 PM
06/18/08 12:00 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I bought new foam for my 71
bucket seats and it appears to puffy on the
back side area around the seat plastic back.
Even more so above the plastic seat back.
Covers are tight but possibly should have reused
the old foam on backs.
logan426
Re: installing new seat covers [Re: OzHemi] #75031
06/18/08 02:35 PM
06/18/08 02:35 PM
Anonymous OP
Anonymous OP
thanks for the info guys, larry
Re: installing new seat covers #75032
06/18/08 06:18 PM
06/18/08 06:18 PM
MD
floyd Offline
floyd  Offline
MD
