Cam removal in a 69 Dart?
#749795
07/16/10 07:35 PM
07/16/10 07:35 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Have any of you switched cams in a 69 Dart with the motor in the car? I'll remove the radiator and fan and the grille, it looks like I'll probably have to remove the front bumper also. I'm wondering if any factory sheetmetal stuff will be in the way. I'm not worried about degree'ing the cam in, I can do that with the heads on and go off the valve spring retainer, I've done it that way and double checked it the next time I had the heads off.
I'm just thinking ahead here, if I get the money together I'd like to have a custom cam before the end of summer. I'm gonna go with a custom Comp cam only because I can get a discount on Comp.
Re: Cam removal in a 69 Dart?
[Re: ProSport]
#749796
07/16/10 07:36 PM
07/16/10 07:36 PM
Posts: 6,295 U.S.
moparniac
U.S.
thinking you got too much dur @ 50 ?
Mopar Performance
[Re: ProSport]
#749799
07/16/10 08:09 PM
07/16/10 08:09 PM
BradH
Sledge, too much overlap, no compression.
Overlap doesn't hurt compression; it's the closing point of the intake valve that determines the cranking pressure. Big duration generally = late closing point = lower cranking pressure.
Too much overlap just makes the idle rougher and delays the point at which the engine "cleans up" when the RPM rises.
[Re: BradH]
#749800
07/16/10 08:57 PM
07/16/10 08:57 PM
ProSport
Akron, Ohio
The cam is a CamMotion roller: 281/283 at .050, 706/661 lift with 1.5 rockers, ground on a 104. We've discussed it here several times and everyone seems to agree it bleeds off alot of compression and isn't at all the 'right' cam for a 500" low deck with 440-1 ported heads, only 11.9 compression, and only shifting at 6600. The cam works GREAT on 93 octane fuel, and I've ran even less octane on the street. So if you're looking for a street roller............. It seems like most here want me to be around 272/282 at .050, ground on a 110, and whatever lift maybe 700'ish. I'll call Comp next week to get their grind recommendation.
[Re: Mopar_Country]
#749805
07/16/10 10:38 PM
07/16/10 10:38 PM
ProSport
Akron, Ohio
I have a 74 Dart and I switched mine with the engine in, I had the radiator and grill out.
[Re: BSB67]
#749806
07/16/10 10:40 PM
07/16/10 10:40 PM
ProSport
Akron, Ohio
In my 68, did not remove bumper or grill.
68 Dart? How did you manage that?
[Re: ProSport]
#749809
07/17/10 08:04 AM
07/17/10 08:04 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
It could probably be done with the grille still attached But I think the latch tray would need to be removed at minimum.
Anyway I pulled the cam out of my 383 in my 69 dart , didn't have to pull the bumper but I did pull the rad , grille and latch tray .
[Re: JohnRR]
#749810
07/17/10 08:27 AM
07/17/10 08:27 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey Bob - Your times look pretty good and so does the 60ft...and runs on pump gas. How much are you hoping to gain from the swap, or are you just looking for better idle quality?
2 kids and a dog
[Re: ProSport]
#749813
07/17/10 08:22 PM
07/17/10 08:22 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Didn't do anything special. The latch support had to be removed.
