A518 Flex plate and converter mount to LA motor? #749462
07/16/10 09:56 AM
07/16/10 09:56 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Can anyone tell me if a 94 A518 / 46RH flex plate and torque converter will work on my 1990 samll block LA motor? (starter line up etc?) or do I need a LA flex plate and converter?
Go Fast and Swerve!
Re: A518 Flex plate and converter mount to LA motor? [Re: way2fast] #749463
07/16/10 03:10 PM
07/16/10 03:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What you have will bolt to the LA motor.
Re: A518 Flex plate and converter mount to LA motor? [Re: way2fast] #749464
07/16/10 05:08 PM
07/16/10 05:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The question though is your 90 motor internal or external balance and is the converter you have there an internal or external balance. BUT be warned I'm 99% sure the magnum external balance is different than the LA external.
Re: A518 Flex plate and converter mount to LA motor? [Re: JohnRR] #749465
07/16/10 05:32 PM
07/16/10 05:32 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
318-LA and 5.2 magnum are both internal balance.
The 360 and 5.9 have different balance.
Re: A518 Flex plate and converter mount to LA motor? [Re: gdonovan] #749466
07/17/10 09:53 AM
07/17/10 09:53 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Thanks!!!! Now I got to get to putting this thing back together
Go Fast and Swerve!
