Re: 318 2 bbl help
[Re: 05dakota]
#74930
06/17/08 11:13 AM
06/17/08 11:13 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Sounds like an electronic carb if its an '84. Those things suck without the electronics hooked up. Can cause all kinds of problems. Whenever I converted my lean burns to electronic, I'd swap out the carb for a 70s BBD
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
Re: 318 2 bbl help
[Re: Paul_Fancsali]
#74935
06/17/08 05:17 PM
06/17/08 05:17 PM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
My old 318 2bbl had a float level problem that caused it to run lean... I've heard that's a common problem with them.
The Blue Goose
My instagram: Bossride
