318 2 bbl help #74928
06/17/08 10:43 AM
06/17/08 10:43 AM
OHIO
K
Krucial_Engineer Offline OP
K
OHIO
bone stock typical 84 318 2 bbl holley
mopar ignition, new ECU, new dist, new coil.
Engine will only run if the choke is 1/2 on, it dies as soon as it is leaned out. Originally thought it was sucking air from a hole in the sending unit, but that didn't do the trick.
Car acts like its not getting fuel, but when I take the fuel filter off, it flows gas. This happened on a 75 mile trek to buy parts, and it just started missing and losing power after an hour on the road.
Carb related? or another junk ECU from autozone?
Re: 318 2 bbl help [Re: Krucial_Engineer] #74929
06/17/08 10:54 AM
06/17/08 10:54 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
vacuum leak?
Re: 318 2 bbl help [Re: 05dakota] #74930
06/17/08 11:13 AM
06/17/08 11:13 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Sounds like an electronic carb if its an '84. Those things suck without the electronics hooked up. Can cause all kinds of problems. Whenever I converted my lean burns to electronic, I'd swap out the carb for a 70s BBD
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: 318 2 bbl help [Re: MoPar Jamie] #74931
06/17/08 11:50 AM
06/17/08 11:50 AM
places
79powerwagon Offline
places
Most BBD's suck too. My opinion is that all BBD's should be used for fish habitat at the bottom of the ocean... but I digress...
If you think you aren't getting all the fuel you are supposed to, double check your fuel lines from the tank to the carb. I had a tiny leak that showed no wet spot and offered no fumes, but was enough to defeat the pump. A few bucks worth of new lines, and never had the problem again!
Re: 318 2 bbl help [Re: 79powerwagon] #74932
06/17/08 12:33 PM
06/17/08 12:33 PM
dogdays Offline
dogdays  Offline
It's carb related and I think a previous poster is on to something. The metering of the feedback carbs uses a solenoid controlled valve to regulate mid-throttle fuel flow. If that is disconnected or fouled up you could have that part of your fuel flow closed off and need to run the choke to suck enough gas through the other circuits to run.
R.
Re: 318 2 bbl help [Re: dogdays] #74933
06/17/08 01:47 PM
06/17/08 01:47 PM
OHIO
K
K
OHIO
I'll check the fuel lines, as well as look at the carb. As rotten as the sending unit was, when I replaced that, I thought it would be the fix.
Anyone have a carter 2bbl in good running shape near cleveland, oh?
Re: 318 2 bbl help [Re: Krucial_Engineer] #74934
06/17/08 04:22 PM
06/17/08 04:22 PM
P
Paul_Fancsali Offline
P
I ahve several I'm in Pittsburgh. Check for vac leak that year 318 loves intake gaskets. By the way the BBD 2 barrel is a very reliable carb. By the way I had a similar problem try adjusting the idle mixture screws and keep them as even as possible
Re: 318 2 bbl help [Re: Paul_Fancsali] #74935
06/17/08 05:17 PM
06/17/08 05:17 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
My old 318 2bbl had a float level problem that caused it to run lean... I've heard that's a common problem with them.
The Blue Goose
My instagram: Bossride
Re: 318 2 bbl help [Re: BossRide] #74936
06/18/08 01:11 PM
06/18/08 01:11 PM
P
P
Forgot to ask did you set the metering rods?
Re: 318 2 bbl help [Re: Paul_Fancsali] #74937
06/18/08 01:20 PM
06/18/08 01:20 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
A customer of mine changed directions on his project after I restored this one for him, he wants $200.00 for it. I just completed a complete restoraton on it, ran great on the mule engine test, I still have it here if you need it.
