8 3/4 gear oil, whats the best? #748884
07/15/10 01:49 PM
07/15/10 01:49 PM
MS, USA
K
killercoronet Offline OP
K
MS, USA
Whats the best oil to run in my Coronet rearend? Its an 8 3/4 with 3:55 suregrip, street car. I was thinking about trying the royal purple. Suggestions?
Re: 8 3/4 gear oil, whats the best? [Re: killercoronet] #748885
07/15/10 01:55 PM
07/15/10 01:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive used regular old gear oil for 45 years.Just add the SG additive.Rocky
Chrysler Firepower
Re: 8 3/4 gear oil, whats the best? [Re: killercoronet] #748886
07/15/10 02:09 PM
07/15/10 02:09 PM
NY usa
540challenger Offline
NY usa
I run royal purple 75w-140 in my 8 3/4 3.55 tru-trac No addtive as my diff. doesn't require it.
Re: 8 3/4 gear oil, whats the best? [Re: 540challenger] #748887
07/15/10 02:49 PM
07/15/10 02:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Any rear end lube that is on sale at your Wallymart or any other store.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 8 3/4 gear oil, whats the best? [Re: MoparforLife] #748888
07/15/10 02:59 PM
07/15/10 02:59 PM
Colo
P
PJ68RT Offline
PJ68RT  Offline
P
Colo
Where can you buy the SG additive?
Re: 8 3/4 gear oil, whats the best? [Re: PJ68RT] #748889
07/15/10 03:10 PM
07/15/10 03:10 PM
NY usa
NY usa
Any autopart store will have it "limited slip additive" A lot of guys including myself like the GM version you can get through the dealer. If you say sure grip additive unless they are a mopar guy expect to see this on the face
Re: 8 3/4 gear oil, whats the best? [Re: killercoronet] #748890
07/15/10 05:45 PM
07/15/10 05:45 PM
Locomotion Offline
Locomotion  Offline
I use Amsoil Severe Gear 75w-90 synthetic in my race car, tow truck and everyday truck. They also have 75w-110 and 75w-140. The lighter viscosity will free up a bit more power and mpg if you don't need the higher viscosity versions.It all has a limited slip additive but on rare occasions, you may have to buy some seperately.
Good stuff which my differential guy like also.
Re: 8 3/4 gear oil, whats the best? [Re: Locomotion] #748891
07/15/10 06:06 PM
07/15/10 06:06 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
BESTest stuff I have found (other than the original skunk-oil) is the Mobil 1 syn gear lube.
Re: 8 3/4 gear oil, whats the best? [Re: therocks] #748892
07/15/10 11:07 PM
07/15/10 11:07 PM
MNobody Offline
MNobody  Offline
Same here, 80-90w with friction modifier.
Re: 8 3/4 gear oil, whats the best? [Re: killercoronet] #748893
07/16/10 05:54 AM
07/16/10 05:54 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
It depends. Do you like your gear oil too thick, too thin, or right within SAE specification?
Southwest Research Institute - KRL 20-Hour Shear Stability Test - pdf link
Re: 8 3/4 gear oil, whats the best? [Re: CompSyn] #748894
07/16/10 11:17 AM
07/16/10 11:17 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The chart does not list the GL rating of each oil. Isn't that a very important factor when comparing shear stabilty?
Re: 8 3/4 gear oil, whats the best? [Re: killercoronet] #748895
07/16/10 11:54 AM
07/16/10 11:54 AM
street car.
as said regular parts house stuff but in a 85-140 wt and a bottle of the skunk additive. I dont think a street car is going to generate enough heat to warrant the expense of synthetics in this app
Re: 8 3/4 gear oil, whats the best? [Re: CompSyn] #748896
07/16/10 02:33 PM
07/16/10 02:33 PM
MNobody Offline
MNobody  Offline
That chart does me no good, there's no Carquest oil listed...
Re: 8 3/4 gear oil, whats the best? [Re: DoctorDiff] #748897
07/16/10 03:29 PM
07/16/10 03:29 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The gear lubes tested in the chart are American Petroleum Institute (API) GL-5, SAE 75W-90 synthetic gear lubes. Samples of API GL-5, SAE 80W-90 petroleum gear lubes were also included for comparative purposes.
The chart is one of many taken from: A Study of Automotive Gear Lubes - pdf. link
Re: 8 3/4 gear oil, whats the best? [Re: CompSyn] #748898
07/16/10 04:24 PM
07/16/10 04:24 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I have Royal Purple in my Dana and it is noise ,I am going back to the stinky stuff.
Re: 8 3/4 gear oil, whats the best? [Re: MoparforLife] #748899
07/16/10 04:51 PM
07/16/10 04:51 PM
BDW Online content
BDW  Online Content
Works for me, used the GM additive suggested by Dr Diff.
Re: 8 3/4 gear oil, whats the best? [Re: BDW] #748900
07/16/10 10:23 PM
07/16/10 10:23 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Well, good ol' 80/90 gear oil kept it together for 40 plus years, so I guess the 80/90 will keep it together for another 40.
Re: 8 3/4 gear oil, whats the best? [Re: Mopar1] #748901
07/16/10 10:47 PM
07/16/10 10:47 PM
IN
ahy Offline
ahy  Offline
IN
There are all kinds of lubes for special situations - drag racing, sustained 130 MPH ect. ... but for you no added value. 80W/90 with the limited slip additive should work fine. Both from the autoparts store.
Re: 8 3/4 gear oil, whats the best? [Re: CompSyn] #748902
07/16/10 10:55 PM
07/16/10 10:55 PM
USA
rftroy Offline
rftroy  Offline
USA
This study is published by Amsoil Inc., and, surprise, Amsoil Severe gear 75W-90 comes out on top.
I'll take this one with a large grain of salt, thank you.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 8 3/4 gear oil, whats the best? [Re: rftroy] #748903
07/16/10 11:15 PM
07/16/10 11:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just another of the endless amsoil ads. He sells the stuff so of course anything he posts about it will make it look best.
