Advice on using 3 stone honing tool #748267
07/14/10 03:17 PM
07/14/10 03:17 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Hi all my buddies motor needs rebuilding and the bores deglazing. We have a three stone hand honing tool but wondered what the correct technique for doing this is? What kind of drill speed , what type oil to use etc etc. any advice would be great!
Re: Advice on using 3 stone honing tool [Re: blown360] #748268
07/14/10 03:44 PM
07/14/10 03:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Up and down pretty quick... your shooting for a 30*
cross hatch.... but if it needs boring have it done
that deglaser wont do that
Re: Advice on using 3 stone honing tool [Re: MR_P_BODY] #748269
07/15/10 01:09 PM
07/15/10 01:09 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Thanks as always MR-P. Think ill try it on an old block first!
Re: Advice on using 3 stone honing tool [Re: blown360] #748270
07/15/10 02:45 PM
07/15/10 02:45 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If your just freshening up the engine and the seal was good and the bores are straight and your only going to rering it and change the inserts,them I would just use a ball hone.The 3 stone hone will remove more material than a ball hone(dingleberry)
