Help I Burned up the IGN 1 wire #747924
07/14/10 03:45 AM
07/14/10 03:45 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I rejetted the Holley 770 carb on my 440 a few weeks back. Took the car for a ride and it pulled much stronger up at higher RPMs but felt a little bit flat on the primaries. I went back home, bumped the timing up 5 degrees, and left. I got about 1/4 mile down the street and everytime I hit the gas the car had an extreme surge. It seemed to be turnning off and on instantly more or less, and would not rev up, just surge.
I pulled into a gas station to check for a fuel leak. It idled fine. I revved it up and it revved ok in park, except for a shutter around 3000 rpm the first time, revved it again and it revved clean. Put it in gear, still idling fine, pulled away and its doing it again.
Im heading home, basically idling down the street, when someone comes up behind me. I give it some gas and its surging. I noticed that the ammeter was slamming back and fourth with the surging. All the way to the end of the range on the discharge side, back all the way on the charge side, very quickly and violently. After about five surges it died out. Smoke starts coming through the cowl. I turned the key to off. I was about 200 feet from home so I ran home and grabbed a fire extinguisher, ran back, opened the hood (expecting a fuel fire) and theres nothing on fire.
On the firewall I noticed melted wires. I pushed it home and took it apart. It seems that IGN 1 at the switch (blue wire with a white tracer) is burned from the switch all the way through the firewall to the connection at the voltage regulator and then to where it plugs in at the ballast resistor. It seemed to be more melted around the voltage regulator/ballast area. I do have my ignition box and my choke tapped in from this wire.
The green field wire on the back of the alternator had an exposed peice of wire laying very close to the housing of the alternator which may have been touching before I messed with the wiring up at the firewall. Im thinking when I moved the timing I pulled this wire (since I had the plug for the dizzy running with those wires in the same area wrapped together) and it touched the alternator housing and shorted out and backfed somehow. What I dont understand is why it only did it under a load under throttle, maybe because the alternator had more to charge? It was at night and the headlights were on. I believe the vent fan was too.
Is it possible a short in the switch would cause this? I have had problems with the switch before.
And is it likely that something else (I.E. carburator) caused the surge, and the wire burned up as a result of the surge?
Any ideas or has anyone else ever had this problem? The car is a 67 Plymouth Satellite if it helps. The wiring is NOT hacked up on this car and I have no other apparent wire damage anyplace else under the dash. The electronic box has been in for about 2 months, and the choke has been wired in there for about a year, so I don't see how something there would have suddenly caused a problem.
Any help is greatly appreciated, fixing what is burned is easy but I do not want to fix it only to burn it up again.
Re: Help I Burned up the IGN 1 wire [Re: GTX MATT] #747925
07/14/10 05:43 PM
07/14/10 05:43 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
No one?
Re: Help I Burned up the IGN 1 wire [Re: GTX MATT] #747926
07/14/10 05:50 PM
07/14/10 05:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The surge was most likely not carb related but ignition fallure. Rewire it and find the cause of the short which was probably the bare alt wire. When you put a load on the engine it might have caused the wire to move shorting it temporarily until it finally stayed shorted.
Re: Help I Burned up the IGN 1 wire [Re: stumpy] #747927
07/14/10 06:02 PM
07/14/10 06:02 PM
Andrewh Offline
Andrewh  Offline
I would pop the bulkhead connector and check for more damage.
What you describe would full field the alt. Causing a serious over charge. Normally I would expect the feed line to burn, not the sensing/ign wire to burn.
Carb is not at rault. It is an electrical issue.
Regardless of how un hacked the wiring is, you still need to look it over now starting with the big wire at the alt all the way through the firewall.
Re: Help I Burned up the IGN 1 wire [Re: GTX MATT] #747928
07/15/10 07:43 AM
07/15/10 07:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you might want to check that again , had a similar thing happen to my dads 72 duster , burned the wires all the way to the ammeter , didn't find the problem till a year or so after the wiring under the hood was fixed by the local repair shop he used. I pulled the cluster to find the harness all melted together and bare wires hitting the back side of the dash. You'll want to have the alt tested .
Re: Help I Burned up the IGN 1 wire [Re: GTX MATT] #747929
07/15/10 03:51 PM
07/15/10 03:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the '67 still has the original charging system the IGN1 wire doesn't connect directly to the alternator.
Re: Help I Burned up the IGN 1 wire [Re: John_Kunkel] #747930
07/18/10 04:05 AM
07/18/10 04:05 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Correct, it connects to the voltage regulator. And for the record it does have a dual field alternator with the second feild grounded out as usual, I dont think it makes a difference but its worth noting.
