Onan Generator 4000 Genset #747688
07/13/10 07:25 PM
07/13/10 07:25 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
When i bought my enclosed race trailer this year it had a Onan Generator 4000 Genseet Emerald Plus in it which the previous owner hooked up.
When i went to use the winch it drained the battery. I found out quickly that when the generator is running it is NOT charging the battery.
There is a plug with a bunch of cut off wires running off the generator.
Anyone know how i can get it to charge the battery?
Re: Onan Generator 4000 Genset [Re: Diablo] #747689
07/13/10 07:32 PM
07/13/10 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL.... same identical unit I have... I have a plug
going to my trailer(gen is mounted in the bed of the
truck)... and I have a battery charger plugged in
for the gen battery... works great..... Oh by the
way there is NO charging circuit on that gen... dont
ya just love it.... that gen was for a motor home
and it used the motor home batteries
Re: Onan Generator 4000 Genset [Re: MR_P_BODY] #747690
07/13/10 07:44 PM
07/13/10 07:44 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I am not that familiar with small onan gas units but the diesel marine units have a dc winding on the main shaft next to the fan , Check the control box cover for a diagram, If it has the winding just run the wires from the box to the batts
Re: Onan Generator 4000 Genset [Re: emarine01] #747691
07/13/10 08:03 PM
07/13/10 08:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It doesnt have a charging circuit... I even bought the
book on it to see what was wrong with it... still didnt
believe the book(who could build a gen without a
charging circuit) so I even called the dealer...
nope, no charging circuit
Re: Onan Generator 4000 Genset [Re: MR_P_BODY] #747692
07/13/10 08:21 PM
07/13/10 08:21 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I have an onan 6500 witch I installed this last winter. I also installed a trickle charger to keep the battery up and it is wired into the panel in the trailer,caution though you need an rv transfer switch If pluging into household power.I bought a RV auto transfer switch for 140 bucks.
Re: Onan Generator 4000 Genset [Re: boatracer572] #747693
07/13/10 08:28 PM
07/13/10 08:28 PM
Lehigh Acres, Florida
rickstershemi Offline
My Onan 7000 doesn't have a charge circuit either....the charger is a separate unit which is energized by either the generator, 12V off the tow vehicle or house power....works slick
Rickster
Re: Onan Generator 4000 Genset [Re: rickstershemi] #747694
07/13/10 08:33 PM
07/13/10 08:33 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The cheep bast...s, its not like they dont charge enough to buy one, My honda pull start has a 10 amp dc side
Re: Onan Generator 4000 Genset [Re: boatracer572] #747695
07/13/10 08:33 PM
07/13/10 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Where I plug into the trailer(underneath the trailer)
is a plug box so its either plugged into the gen OR
plugged into the shop... I cant do both... only 1
plug
EDIT or I can plug in at the track if they have power
Re: Onan Generator 4000 Genset [Re: emarine01] #747696
07/13/10 08:37 PM
07/13/10 08:37 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
hey wait a minute, how do they run the spark and fuel pump with out supplying a charging source
Re: Onan Generator 4000 Genset [Re: emarine01] #747697
07/13/10 08:43 PM
07/13/10 08:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
12v battery source same as for the gererator starter, my motor home uses a add on battery charger to keep the auxillary battery charged and that battery power's the light's and any 12v used in the home except for starting the motorhome it'self and that is a seperate source.
Re: Onan Generator 4000 Genset [Re: emarine01] #747698
07/13/10 08:44 PM
07/13/10 08:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its drawing on the batt... my fuel tank is a 35 gal
aux tank under the truck so I have a small pump to
move the fuel up to the carb and its drawing on the
batt all the time when the gen is running... thats
the reason I have a battery charger hooked to the batt
maybe thats why they offered a separate charging unit
Re: Onan Generator 4000 Genset [Re: MR_P_BODY] #747699
07/13/10 09:09 PM
07/13/10 09:09 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I never liked Onans, We call them O-no-s in the shop cause they suck, parts are way over priced and they are built as cheap as they come, 20 years ago they built good units now its just a popular name, how can they sell a power generating plant that is not self contained and a parasitic load on another system, I know its not too big a deal to plug in a charger off the ac side but they should have that built in for the bux they charge .... Sorry guys I don't know where that came from
Re: Onan Generator 4000 Genset [Re: MR_P_BODY] #747700
07/13/10 10:55 PM
07/13/10 10:55 PM
San Jose Ca.
San Jose Ca.
plug
The problem is you half to isolate the nutrals via dis connect or tranfer switch while pluged into city power or you back fead the gen. through the nutrals,and the city power company always wins!!!
Re: Onan Generator 4000 Genset [Re: boatracer572] #747701
07/13/10 11:26 PM
07/13/10 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
plug
The gen CANT be plugged in if I'm on HOUSE power
2 separate wire hook ups(I have to unplug the gen
if I want to use the house power)... basically I
have a extension core going to the one and only inlet
from the gen to the trailer(its underneath) so its
a either or, not both
Re: Onan Generator 4000 Genset [Re: MR_P_BODY] #747702
07/14/10 08:05 AM
07/14/10 08:05 AM
plug
Same here and keeps all the house batteries charged while hooked up to the house power, also have a sewer dump / wash-down at the same location
Rickster
