Re: brake light in dash stays on..??
[Re: toplescuda]
#74765
06/16/08 10:46 PM
06/16/08 10:46 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
there is a switch on the e brake foot pedal, like the dome light switch in the door jam. might need adjusted. as foor the other lights, check the fuses and connections.
1981 Dodge D150 360 auto
[Re: basketcase]
#74766
06/16/08 11:00 PM
06/16/08 11:00 PM
Posts: 3,386 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Also could be a bad connection where the wire hooks to the brake proportioning valve / d-block on the drivers side inner fender.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: basketcase]
#74767
06/16/08 11:04 PM
06/16/08 11:04 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
does the brake/tail lights run a fuse? i thought thay had own system with the headlights??
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#74769
06/17/08 12:49 PM
06/17/08 12:49 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
brake lights shares same dome light fuse... also glovebox
parking lights/sidemarkers and cluster, shares same fuse, even cluster lights have an EXTRA one from the lights switch dimmer output
brake light at cluster is double function. Emergency brake and brake fluid pressure fail at dist block
[Re: toplescuda]
#74771
06/17/08 05:36 PM
06/17/08 05:36 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
I would say you have a grounding issue. Sounds like it's trying to find ground through the brake warning light.
Pull the cluster, clean all the contacts, inspect all the pins and add a new ground.
Secondly, if after this things begin to work but you still don't have park/dash lights, I would recommend changing the headlight switch. 99% of the time, the dimmer rheostat is bad and/or the park circuit of the switch is toast.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: DirectSubjection]
#74774
06/20/08 01:36 AM
06/20/08 01:36 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
Take the drivers side kick panel out to get to the taillight harness and see if you have power there. Seems like something isnt right that you dont have any lights back there. If it was the turn signals I would suggest the turn signal harness in the steering column, and the brake lights could be the switch on the brake pedal. As far as the dash brake light stuck on check the e-brake pedal to make sure it is all the way up.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
