904 to 727 console shifter #747156
07/13/10 02:36 AM
07/13/10 02:36 AM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Ok so i have a console shifted 904 in my dart right now, soon itll be a 727. Is there any difference in the linkages or anything that will prevent me from using the stock shifter? Thanks.
Re: 904 to 727 console shifter [Re: 69B3GT] #747157
07/13/10 12:57 PM
07/13/10 12:57 PM
california u.s.
dodge41969 Offline
dodge41969  Offline
california u.s.
No, the tranny sits in the same location,you'll need a shorter driveshaft though w/the 727 slip yoke,there's a bracket that bolts to the trans. you'll need off the 904.
Re: 904 to 727 console shifter [Re: dodge41969] #747158
07/13/10 03:23 PM
07/13/10 03:23 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Alright ill be sure to pull the bracket, im going from a 273-904-7 1/4 to 440-727-8 3/4, I have the correct driveshaft I just wasnt sure about everything else. Thanks.
