Page 3 of 3 1 2 3
Re: What MSD doesn't tell you. [Re: Crizila] #747106
07/13/10 04:09 PM
07/13/10 04:09 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
do you know any Robert Frost poems hidden in your subliminal mind?
There was an old man from Kent,.....
U mean Nantucket!
I heard about that dude...
Re: What MSD doesn't tell you. [Re: Hemiroid] #747107
07/13/10 04:17 PM
07/13/10 04:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you haven't seem OE ignitions fail and not provide spark then you might want to back out of this discussion due to a lack of information and real world experience.
I cant count how many dist pick ups I've changed in
the 4 cyl engines in the 80s when I worked in a Chrysler
driveability shop
Re: What MSD doesn't tell you. [Re: GregCon] #747108
07/13/10 04:34 PM
07/13/10 04:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
As for "MSD is the most successful so that makes them the best" let me list a few others that would fit into that category:
Chevrolet (in the 1960's)
Microsoft
GE
Michael Jackson
Jesse Jackson
Oprah Winfrey
AT&T
So we see that the skill of learning how to be sucky and make people still buy your product is not to be confused with 'best'.
where did you come from? ever think about going back
Re: What MSD doesn't tell you. [Re: Quicktree] #747109
07/13/10 04:43 PM
07/13/10 04:43 PM
sweden
sshemi Offline
sshemi  Offline
sweden
WOW....
Re: What MSD doesn't tell you. [Re: MR_P_BODY] #747110
07/13/10 05:10 PM
07/13/10 05:10 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
well as a student of auto electronics, take this exp as a learning curve. nothing else.
like BG said every Co has its kooky mgrs and workers who only look out for the bouns.
anyway the problem at hand is your sine input Vs the needed digital.
you dont explain if you need a leading edge and at what level of triggering was required. a simple lookl with an O scope will clear that up. asle a clamping diode will clean up your rising and falling edges of the pulses.
ive fixed dozen ignitions and every unit has different "clean" input requirements.
im sure since you are top dog student you realized you probably got a magnetized reluctor by some dummy using a steel feeler gauge and therefore providing that sine magnetic pulse. check it with a gauss meter and let us know.
you can fire a digital with a 45% slope on input sooo something is not right in whooville today.
Re: What MSD doesn't tell you. [Re: BobR] #747111
07/13/10 05:39 PM
07/13/10 05:39 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
"There once was a hermit named Dave
who kept a dead---in his cave,"
If you like drag racing, support your local track.
Re: What MSD doesn't tell you. [Re: HemiRick] #747112
07/13/10 05:42 PM
07/13/10 05:42 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
."trigger polarity...". VERY important! I've been told by many that it makes no difference...BUT, I KNOW from past experiences that MSD must have a color blind person putting the leads in the connectors.
I 2nd this, I've had the same issue with my MSD 6. The polarity of the wires from the dist must be right for some units to work...
If you reverse the wires it will change timing as much as 30 degrees. One direction the wires give a reading off the front of the reluctor and the other way it reads off the back of the reluctor as it goes by.
Guess how I know this?
Re: What MSD doesn't tell you. [Re: Monte_Smith] #747113
07/13/10 05:44 PM
07/13/10 05:44 PM
Arizona
Chris'sBarracuda Offline
Arizona
OK, name an ignition system you think is BETTER than MSD and tell us why....not just because you say so.
Monte
I think the Crane HI-7 and HI-8 ignitions with the DEC9500 boxes were the best when they came out 10+ years ago, and still work as good if not better than any MSD units.
It's really too bad Crane didn't market those any better, they are very dependable. Alot of the Pro Stockers used them until they were mandated to use the MSD 7530T ?? box. I know Warren Johnson used Crane till the very end.
Anyway, I still use my Crane with no issues, after getting rid of my MSD which always had issues. I have two spares, so I'm good till I die..
Chris..
Re: What MSD doesn't tell you. [Re: B G Racing] #747114
07/13/10 05:55 PM
07/13/10 05:55 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I think you are part of a conspiracy put in place by MSD.A sleeper cell do you know any Robert Frost poems hidden in your subliminal mind?
Oh man ............ that is the funniest bit of writing I have put eye to in a good bit.
Way funnier than I expect from a " serious " forum like this.
Bob , I'd love to expound on your comedic brilliance some more , but as you well know , The woods are lovely , dark and deep.
But I have promises to keep......and miles to go before I sleep.
Miles to go before I sleep.
Nope , not a Frost fan per se , but a huge Charlie Bronson fan.
Re: What MSD doesn't tell you. [Re: Chris'sBarracuda] #747115
07/13/10 06:04 PM
07/13/10 06:04 PM
HemiGreg Offline
HemiGreg  Offline
Re: What MSD doesn't tell you. [Re: HemiGreg] #747116
07/13/10 06:05 PM
07/13/10 06:05 PM
HemiGreg Offline
HemiGreg  Offline
Re: What MSD doesn't tell you. [Re: HemiGreg] #747117
07/13/10 06:06 PM
07/13/10 06:06 PM
HemiGreg Offline
HemiGreg  Offline
Re: What MSD doesn't tell you. [Re: Hemiroid] #747118
07/13/10 07:12 PM
07/13/10 07:12 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
"If you haven't seem OE ignitions fail and not provide spark then you might want to back out of this discussion due to a lack of information and real world experience."
In the real world, if I was you, I would read what is written before I reply. Nowhere did I say what you posted. I said CONTEMPORARY.
Re: What MSD doesn't tell you. [Re: GregCon] #747119
07/13/10 07:20 PM
07/13/10 07:20 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
HemiGreg has humble us all again.
Re: What MSD doesn't tell you. [Re: B G Racing] #747120
07/13/10 09:05 PM
07/13/10 09:05 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
To the 5th power
trying to learn something new but now I'm all backwards
Re: What MSD doesn't tell you. [Re: B G Racing] #747121
07/13/10 09:09 PM
07/13/10 09:09 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Monte
W&H Daul Coil and Fairbanks Morse if we were back in the 1950s Just kidding Monte,I want to see if I could sound as stupid as some of the brilliant comments.Barry Grant,Indy,MSD and many others get bashed cause of someones fkups.Usually if someone has a ligitimate claim the manufactures bend over backwards to help.Most issues is caused by frustration and attitudes.
You've got to be kidding about Barry Grant.
Re: What MSD doesn't tell you. [Re: SCDaytona] #747122
07/14/10 02:17 AM
07/14/10 02:17 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Polarity is an easy check. You fire the car and check the timing. Swap the connector wires, fire it and check again............Now, if you have an Analog box, the wiring that gives the lowest timing number is correct. A Digital box, will be wired correctly with the highest number. The difference is usually 4-8 degrees. Also, if you have a "locked" dist, or a crank trigger and the timing "backs up" as you raise rpms, the polarity is likely backwards.
Monte
Re: What MSD doesn't tell you. [Re: Monte_Smith] #747123
07/14/10 06:42 AM
07/14/10 06:42 AM
tboomer Online work
tboomer  Online Work
MSD 6AL here..It takes a lickin and keeps on tickin...And if it failed...I would get another one!!
Re: What MSD doesn't tell you. [Re: tboomer] #747124
07/14/10 07:10 AM
07/14/10 07:10 AM
sweden
sshemi Offline
sshemi  Offline
sweden
WOW again.
Re: What MSD doesn't tell you. [Re: sshemi] #747125
07/14/10 03:50 PM
07/14/10 03:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My take on MSD is this.
Over the years i have had a few MSD boxes, and for the most part they have worked fine. I did have a problem with a 6AL a few years back, that i proved was in the box, but hey, stuff breaks, nothing is infallible.
What MSD enjoys is a virtual stranglehold on the performance ignition market.Its a niche market that they OWN.
Pretty much any magazine you look at, the various prices you see they're stuff listed for are identical, same pretty much with Jegs, summit and everybody else, with very rare exceptions.
As they have hardly any competition, and its unlikely anybody is going to step up and spend the R&D and initial investent and marketing money to challenge them, its very likely the generally poor customer service they provide will ever get any better. Why would it, no other company makes a similar product that would force MSD to keep they're feet to the fire from a " treating customers great" standpoint.
Its kinda like the car business 25 years ago, only the domestics were out there, and say what you will, quality was many times lacking.
With the Japanese and everybody else now offering cars here, it has " forced" the product across the board to be better. Its just a plain old fact that that is how it is.
MSD has nobody, competition wise, to force them to do the above. Its actually somewhat of a feather in they're cap that the products are as reliable as they are with this being the case.
Long story short, they aint perfect, and they are a little crusty to talk to, but they own the only game in town
Kinda like Indy in some ways
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Page 3 of 3 1 2 3
