110 octane fuel??? #746936
07/12/10 09:25 PM
07/12/10 09:25 PM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
I have a 69 Charger w/ a rebuilt 383. It is .030 over, 906 heads, performer intake, and a holley 650 and headers. THERE IS A PLACE NEAR BY THAT SELLS 110 OCTANE RACING FUEL. I HAVE HEARD THAT IS DOES SOME GOOD to put some in once in a while. Is there an advantage? what does it do for me? if so, what mix to use ???
Re: 110 octane fuel??? [Re: lukendan] #746937
07/12/10 10:03 PM
07/12/10 10:03 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
The race fuel has lead in addition to the higher octane which will help the valve seats if you do a lot of driving. A 906 head 383 can get by with 93 pump gas if compression is held to 10.0 to 1. The open chamber design is prone to detonation if compression is higher and timing more than 34-36 degrees total. If it'll run on 93 without pinging, I wouldn't bother with race gas (most people use a 50/50 mix if they need it).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 110 octane fuel??? [Re: lukendan] #746938
07/13/10 10:40 AM
07/13/10 10:40 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Smells great!
Re: 110 octane fuel??? [Re: Kirby] #746939
07/13/10 10:42 AM
07/13/10 10:42 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If you don't need the extra octane, it will produce less power in your car.
Re: 110 octane fuel??? [Re: lukendan] #746940
07/13/10 11:46 AM
07/13/10 11:46 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
No gain to be had in you application just a power loss as too much octane kills power.
you would have to add 110 to every tank to help save your seats not once in a while.
use 93 and get some of this
http://www.summitracing.com/parts/RED-60202/
Re: 110 octane fuel??? [Re: Dodgem] #746941
07/13/10 06:38 PM
07/13/10 06:38 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have to ask, why would too much octane lower the power output? I would have thought, as least what I have read, that if the engine didn't need it, you were just wasting money. Can someone explain this please?
Re: 110 octane fuel??? [Re: Dodgeguy101] #746942
07/13/10 06:49 PM
07/13/10 06:49 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
The actual energy content is lower with higher octane; higher octane takes MORE energy to ignite and more energy (heat) to keep the combustion going.
Octane is basically resistance to ignition.
Re: 110 octane fuel??? [Re: Dodgeguy101] #746943
07/13/10 08:09 PM
07/13/10 08:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
And because it takes longer to burn more of the burn goes out the exhaust and not forcing the piston.
need's higher compression to be efficient
